PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. arb
  2. track car pics
  3. cosworth loom on rs turbo
  4. Help with these pictures!!
  5. engine bay wiring pic resquest
  6. Threads asking for Car Stereo codes are not allowed.
  7. CVH Dipstick tube
  8. fan fuse keeps blowing!
  9. G407 OKM or G972 RUF Looking for my old Rs turbo
  10. cossie 4 pots
  11. Koni suspension top thread lengths
  12. adding the optional fuel computer?
  13. brake pipe help please guys
  14. OPIE Oils Advertising in Forum
  15. strange windows
  16. brake master cylindre
  17. what benefit is had from fitting a big valve head?
  18. looking for a genuine front wing..
  19. Air Filter
  20. Winter prep??
  21. MK3/4 widearch kit
  22. Bogging out, lost loads of power, smoking????
  23. S2 Brake upgrade
  24. URGENT!!! part needed
  25. brake servo
  26. correct rear decal
  27. problems after rebuild
  28. ke jetonic boost sensor pipe
  29. stage 2 turbos and 5th injector
  30. revving itself!!
  31. Injector sizing/flow rates
  32. Zetec turbo boys. What turbo you using ?
  33. little help here please
  34. A few problems
  35. heater not working..
  36. rs turbo
  37. Intercooler choice
  38. oil pressure on zvh
  39. red E plate s2 spotted
  40. piper 285t cam lube.
  41. rs turbo series 1 exhaust
  42. S1 & S2 light rubbers
  43. Head mods?
  44. My new S2, and a few questions!
  45. EFi What year?
  46. Alloys
  47. Rs turbo set up
  48. s2 escort rs turbo rack replacement
  49. S2 metal fuel lines
  50. IB5 bearings in BC case..
  51. £2500
  52. winter resto in my s1
  53. escort rs turbo
  54. Track car build
  55. (Wanted) s1 body kit
  56. Arp con rod bolts
  57. fitting a new oil pump?
  58. Xr3i cabbie efi to frst engine?
  59. No spark (Sorted!)
  60. you opinions on a new turbo engine build?
  61. aquamist mf2?
  62. steering column wanted
  63. going for a spin
  64. white smoke
  65. Is this hoofed?
  66. turbo knowledge needed!
  67. rst mfi metering units
  68. AEM vs Innovate
  69. 90 spec S2
  70. scuttle panel
  71. f*cking tin worm :(
  72. Banjo bolts metering unit
  73. Zetec sumps and flywheel question
  74. Inlet manifolds as on main room
  75. screen pillar
  76. Throttle cable
  77. Another cold start problem
  78. CVH wossner piston rings help
  79. Recharging problems??
  80. Symptoms of faulty dizzy/sensor?
  81. Boost peaking...
  82. 2l zvh conversion
  83. co srew adjustement
  84. Gearbox question. Update 27/9/12
  85. electrical problem?
  86. wat driveshafts
  87. rs clocks in to my base model
  88. bonnet latch help
  89. tailgate
  90. Rs 500 intercooler
  91. Catalytic converter on RST
  92. new bootlid
  93. rs turbo front badge colour
  94. gearbox is out
  95. Rod pin removal
  96. series 1 interior
  97. series 1 interior
  98. what batterie?
  99. Escort rs turbo tie bar/wishbone washers
  100. like this
  101. Compbrake
  102. S1 master cylinder on a s2
  103. S1 ZT started up for the first time with some pics.
  104. need abit of help guys
  105. ZVH Starting Trouble
  106. 1.8 zetec turbo engine swop
  107. converting s1 to zetec
  108. how do you adjust the metering head?
  109. GOOD BODYSHOP.....????northants? bucks?
  110. Photos of indicator fitting
  111. HELP fitting new mk5 clutch pedal and quadrant.
  112. shuttin down my boost
  113. Anyone got a spare starter motor?
  114. escort rs turbo kit
  115. lsd testing
  116. car not start
  117. cps sensor
  118. Sill strips.
  119. Rev Counter Not Working
  120. what else is needed
  121. Series 2 arb with mtx??
  122. first time starting rebuild engine.
  123. Holding back when comes on boost.
  124. S2 RST without engine, box, clutch..
  125. xr2i block
  126. Ofab air temp sensor?
  127. zetec manifold - over the gearbox type
  128. Rocker arm, which is this?
  129. oil n overheating
  130. fitting turbo
  131. Cooling?
  132. whats best to do a zvh conversion silver top or black top and the easyest?cheapest?
  133. oil in top turbo pipe
  134. efi conversion
  135. rs turbo will not start
  136. RS1600i ARB fitting
  137. just fitted zvh now wont start
  138. any1 got rst s2 coolant n ancillary pipes for sale???
  139. Wiring help
  140. What's it worth?
  141. mk4 front wings
  142. edis
  143. dsw
  144. My s2 ERST
  145. Which final drive is best? s1 or 2?
  146. Zvh Cost
  147. Rear Disc Conversion on MK4 Van? Possible?
  148. Hi-Spec 283mm fitting guide?
  149. This cant be right surely?!
  150. Which Head Gasket
  151. need help please!!
  152. rs turbos in or around aberdeen
  153. 300 bhp rst ??
  154. dipstick
  155. rs s2 boost
  156. New member saying hello
  157. Efi fly wheel
  158. head gaskets
  159. m,o,t tommorrow
  160. Rs turbo won't start when cold
  161. driveshaft query
  162. are all blacktop 2.0 engines the same?
  163. mtx75 gbox for a zetec turbo build
  164. Running in rebuild engine
  165. Knocking from dash it seems
  166. how fast
  167. s2 pulling left?
  168. anyone got a oil return pipe that sits inside the sump need one asap! :)
  169. boost prob, all fixed ;)
  170. rs turbo s2 rad opinions
  171. Do I? mongoose to magnex??
  172. efi conversion
  173. rs 1600i front arb ???
  174. Reverse switch
  175. garrett t3 exgaust houseing
  176. garrett t3 quick question
  177. rs turbo piston diameter ???
  178. What engine oil in rst
  179. *** Buyer beware: H181HCT - Escort RS Turbo S2 ***
  180. VIN plates - help !
  181. Strut brace
  182. How to remove a battery tray
  183. clutch
  184. Fuel pump help.
  185. con rod confusion
  186. Using Water
  187. What sort of power?
  188. vehicle speed sensor
  189. Ticking noise
  190. Tubular manifolds
  191. Escort Rs Turbo Inlet manifold wiring plugs
  192. Engine rebuilds
  193. series 1 rs turbo custom for sale
  194. fooking thing
  195. where can i get carbon fibre door cards?
  196. Engine issues! please help.
  197. Still not 100% sure on wheel colour and colour scheme
  198. injectors change has brought doom
  199. 1.9 cvh 36-1 trigger
  200. Coilpack spacer
  201. How can i measure the sizes of my valves?
  202. Changing the fuel sender advise
  203. inlet manifold
  204. wat con rods
  205. Help with fitting new seats
  206. long shot?
  207. ARP rod bolt torque setting
  208. alternator pulley what colour blue?
  209. aftermarket management
  210. boost controller??
  211. Thermostat Bolt Thread Size?
  212. Set up good and bad news
  213. running on 3 cylinders
  214. Whats the part called...
  215. RS turbo conversion
  216. Adjustable Rear Tie Arms
  217. Possible oil pressure problem (Burton's HP Pump)
  218. Thread Size of COLD START OUTPUT on metering head
  219. EFI Problem
  220. escort rs wont start?
  221. Custom shafts for MTX into s2
  222. carrier pipe
  223. rs turbo gearbox convertion to a 6 speed
  224. Escort Cab rear shocks
  225. Prices of .63 housings these days?
  226. anyone know this car
  227. Rad Fan
  228. FAO peeps using oil coolers and gauges
  229. Anyone fancy a try at this
  230. what gearbox should i buy
  231. Push-on fuel connectors
  232. Standard tuning
  233. Rs turbo (E646 DTA)
  234. clio diffuser on an s2 rear bumper
  235. fuel gauge not working
  236. S2 overboosting!!
  237. best clutch kit without mods?
  238. Thoughts on 1.8 ZVH turbo using MFI
  239. Smoke????
  240. Another ebay joker !! :-) :-)
  241. metering unit
  242. S2 rs turbo water pump/tensioner
  243. Dynocom R/R.
  244. mfi porsche injectors ??
  245. Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hh help me lads
  246. steering lock
  247. RS turbo exhaust
  248. cam timing piper 285t2 help please
  249. rs turbo s2 wont start?????? help!
  250. oops
