Zetec turbo boys. What turbo you using ?
What turbos are you guys running on your full zetec turbo conversions ?
What psi you running and what bhp you getting ?
Thinking of using a t28 I've picked up but aimIng for 300bhp and it might not cope.
Steve
Steve
My spec will be
Blacktop 2.0 zetec
2.1 rebore
Pec steel rods and wossner pistons
Rover turbo inlet manifold
Over gearbox exhaust manifold
Omex 600 management
Standard head
Just unsure wether to use my stage 2 t3 , my t28 or get in trouble with the wife and buy something bigger.
Blacktop 2.0 zetec
2.1 rebore
Omex 600 management
Standard head
Standard ford pistons? That's not going to last long with a t34 isit? Unless your only going for like 220 odd bhp, but then your going to have a laggy turbo with no real punch?
Theyre enough for what I want out of the engine. If i was aiming way past 300 proper rods and pistons would be on the shopping list!
no, only want 300bhp and in a light S2 shell should be fun
wossner pistons.
I would imagine that the ford pistons are nearly as good as cosworth pistons.
If you wanted to run lots of boost and/or power I would have custom pistons made by cp or cosworth.
The mass produced forged pistons will probally be far "better" than
pec or wossner pistons.
Are you on crack ?
Can't see how mass produced ford items like st170 would be better than say wossners.
St pistons need to be replaced for something like wossner if you plan on running over 300 bhp.
Otherwise everyone would be using st pistons.
There's different alloy and different processes used to forge pistons and the strength and quality varies quite significantly
roller bearing tt t38 with tial external gate
no lag what so ever
revs like a motor bike lol
good old ian howell
its all about speccing the hole packege
not just slapping a turbo on and hoping for the best (not saying you are)
no lag what so ever
good old ian howell
As it's been mentioned, ST170 pistons are NOT proper forged items the same way something like Wossners are. So no, they aren't better.
Back to the original question, a T34.63 is a good match for the engine on lower spec and on higher spec GT30.71.
I understand where your logic is coming from, I would agree that standard ford pistons are better in the sense they would last alot longer then a set of forged pistons, but there's no way that they are designed to take almost double the power and torque for a long period of time, therefore I will stick with saying that, forged pistons are better! And for 300bhp and similar torque figures I woudnt risk my engine, turbo etc etc on standard pistons, but good luck all the same!
i would get a mk1 frs turbo and have it rebuilt to john frs hybrid spec, by time you sell your other turbos you will be half way there...
they are very responsive, rev like mad to the limiter and depending on which spec you go for he does them for 340bhp and upto 400 i think....
or just use the low lag gt28 turbo...
Matt Baxter
16-09-2015 08:30 PM
