s2 pulling left?
Old 02-10-2011 | 08:26 PM
drl's Avatar
drl
Default s2 pulling left?
Ok so have another problem thats confused me!
I changed track rod ends and lower arms and the tracking was out (it wanted to go right) got two tyres fitted den tracked up and nw d car pulls left??? i had d garage check tracking again and it was spot on (garage used laser tracking) but car still pulls left?? i checked tyre pressure and thats all even ..... any suggestions?
Old 05-10-2011 | 12:13 AM
I rip people off's Avatar
I rip people off
My s2 does that its annoying I know elite set my car up they have good lazer tracking tools. When u put your put ya pedal to the metal does your car straighten up, please some correct me if I am wrong but it might be the thrust angle
Old 05-10-2011 | 07:52 PM
drl's Avatar
drl
When I floor it the car wants to go left a lot more - doesn't straighten up at all. What's thrust angle?
Old 06-10-2011 | 01:00 PM
MARTCOS's Avatar
MARTCOS
MARTCOS
either that or check your wheel bearings as mine does the same thing and pulls to the left, jacked the car up and rocked the wheel and and theres movement so, that segusts to me bearings are knackered
cheers ian
Old 10-10-2011 | 01:38 PM
drl's Avatar
drl
My front left wheel bearing has some play in it and i can hear a rumble from it, but would a worn wheel bearing cause my car to pull left?
Old 25-10-2011 | 09:59 PM
drl's Avatar
drl
Ok so have have changed both front wheel bearings and car STILL pulls to the left ..... I'm thinking that the tracking wasnt set right, they put gauges on my
Front wheels to adjust toe, can you adjust camber? Could it be anything else?
Old 01-11-2011 | 06:27 PM
kermitt's Avatar
kermitt
If pulling left under power check your engine mount and gear box mounts for wear. Wheel bearings will not cause it to pull to either side.
Camber is not adjustable.
timsrs
13-11-2018 11:48 AM
tankybaby66
06-02-2016 02:24 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
Fudgey
17-09-2015 01:06 PM
Quick Reply: s2 pulling left?
