PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. S2 Front Door Cards Into S1
  2. Turbo seals
  3. Rs 7 spoke 16in
  4. Fuel lines
  5. power steering and Ideling RST in MK5
  6. what petrol??
  7. fuel pump
  8. molding in the body kit
  9. my series one cab whats next for power?
  10. cps efi conversion hole
  11. efi help
  12. clutch help
  13. some help needed
  14. t34 on rs turbo?
  15. my future spec...
  16. Install A B&m Quickshift On S2
  17. Look what i got!!!
  18. 12v supply for boost gauge
  19. Efi Conversion plate
  20. mk 5 pedal conversion
  21. car wont run properly
  22. what rebuit engine to go for
  23. plumbing oil swirl pot
  24. thermostats
  25. cosworth disks on rst
  26. zetec turbo pistons
  27. bypassed abs but
  28. escos wheels
  29. wiring diagram anyone?
  30. Im back with my new S1
  31. Ebay Help
  32. Anyone seen this before?
  33. signs that its the stem seals causing smoke?
  34. escos wheels
  35. Need Go Faster Parts!
  36. Need Go Faster Parts!
  37. irratical idle
  38. mtx 75 gearbox in rst
  39. Need part no. for RST2 LSD gearbox
  40. Rst Rear Brake Hoses
  41. 2wd braided hoses
  42. RS Turbo adjustable tappets what gap???
  43. thoughts please
  44. What size bolt...
  45. running a turbo on an xr3 tank
  46. 18" wheels on escort mk3/4's
  47. Escort Rst Scorpion Exhaust
  48. finis code needed
  49. Show cages
  50. parts
  51. welding onto a gearbox
  52. Rev limiter raised to 7100
  53. Turbo pipe and other parts
  54. Whats the difference.......
  55. 5 stud wheel conversion
  56. zetec/zvh breather fittings
  57. escort s2 dashboard (rev counter)
  58. converting xr3i inlet to efi..............
  59. pic of my s2 comments please. more to come
  60. what oil to you use!!!!!!
  61. leather out cab, rear bench fit ?
  62. Whats the best fmic and alloy rad combo
  63. not going into gear when warm
  64. 16i gearbox
  65. annoying misfire occassionly!
  66. pollished rs turbo wheels
  67. my new rst
  68. ford stripes
  69. 400bhp rs turbo
  70. Boot Space
  71. Mk4 Leather??????
  72. gearbox question
  73. will a alloy radiator keep my car cooler ?
  74. efi conversion best product...?
  75. lack of power
  76. a couple pics of my s2.
  77. any body had a 4 speed rs turbo?
  78. RST won start... :(
  79. rover turbo inlet
  80. rst front mount
  81. release bearings...
  82. Few pics of my S2
  83. suspension choice?
  84. Buying
  85. what springs are these?
  86. Cold start problem?? Help!! updated
  87. Engine bay
  88. Vibration
  89. S2 Gearbox mounts
  90. rear bushes
  91. anyone with diamond cut 7 spokes help
  92. couple of pics of my mint series 2.
  93. Group a coil on rs turbo? help.
  94. rs turbo crank
  95. Are these rear clusters rare?
  96. Gear lever plate
  97. Sump
  98. whats needed to convert MFI to EFI?
  99. cosworth management
  100. rst runing on 3
  101. Good place to get my head skimmed.
  102. series 2 rs turbo wheels
  103. ecu chip
  104. help plz
  105. zvh?
  106. Cold starting problems
  107. Did all Series2 turbos come with factory fitted sunroofs??
  108. zetec turbo
  109. would you feel the difference with 15's?
  110. What colour Rocker ???
  111. boot release prob
  112. Where to get Adj tca's from
  113. Head Gasket Woe.
  114. Exhaust Tailpipe Size For Mongoose
  115. brake calipers
  116. Escort MK4 Petrol Cap
  117. Beter handling/grip etc
  118. gearbox rebuild s2
  119. black 90 spec g or h reg ?????????
  120. S2 Gearbox issues...
  121. Wiring loom help please
  122. cvh valves
  123. which is the better to zetec turbo ??
  124. my old s1
  125. s2 fueling prob
  126. Petrol Cap Keys
  127. does anyone know this car?
  128. alloy whell refurb
  129. airtec intercooler fans
  130. Is it worth getting back into the money pit?
  131. What is this... ???
  132. Blacktop to ZVH
  133. wilwood dealer??
  134. Rear gerbox mount
  135. most eficient FMIC for a s1/mk3 escort
  136. Suspension Arms
  137. S2 Mudflaps - Opinion please
  138. s2 headlights
  139. Grp A coil
  140. Water cooling turbo
  141. cossie 4 pots
  142. running probs could this be the cause?
  143. stage 2 t3 hybrid....
  144. Engine In the Top
  145. repair arch panels??
  146. 5th injector
  147. boot release
  148. mfi - efi
  149. hole for crank sensor
  150. zetec turbo or zvh
  151. electric window relay
  152. does the box have to come out aswel ?
  153. zetec turbo best c/r
  154. Swaping speedo dials to white ones?
  155. Front mount, which one?
  156. which ecu for zvh?
  157. Trim needed
  158. what should i replace ??
  159. Exhaust Help
  160. slow to build and hold boost??
  161. compression help
  162. rs turbo breathers
  163. WHERE CAN I GET A 5TH INJECTOR
  164. gettin keys cut
  165. zetec head cc
  166. rs turbo bonnet
  167. ib5 gearboxes......
  168. Engine swap!
  169. New S2 Petrol Tank. Where from?
  170. best inlet for 2.1 zvh
  171. Where and how much to rebuild series 1 rst gearbox?
  172. pics of my xr3 turbo
  173. wolfrace voodoos or standard
  174. corrie turbo
  175. zvh to full zetec turbo
  176. stand of rear chassisrail
  177. opening the bonnet
  178. What size FMIC
  179. My 1st run at Crail
  180. GEARBOX PROBLEMS
  181. How would you go with this Erst, ambers etc or clears
  182. Brakes - need to press them hard
  183. Removing ABS etc
  184. Magazine
  185. Help from Scottish members req.
  186. insurance
  187. Replace My Old T3 For Stage3 T3
  188. 2wd discs and pads ?
  189. Series 2 custom charge pipe
  190. how long to fit polybushes?
  191. knife edging and tuftridning crank ??
  192. whats the better bottom end to use ??
  193. standard rods... how much will they handle?
  194. F.A.O, all the EFI experts,ofab wiring plug. 7 wires.????
  195. S1 / S2 metering heads
  196. MK3/4 Escort & Side mount bucket seats
  197. HOWYA HORSE
  198. S1 FORD WINDSCREEN
  199. series 1 and series 2 differences
  200. should i go zvh ??
  201. egt's
  202. how many left?
  203. What pistons and rods to use.
  204. ploybushes is to fit?
  205. Power steering
  206. best turbo for 200bhp
  207. GAS STRUT BONNET CONVERSION
  208. Stainless Steel Valves vs. OEM Valves
  209. amel valve
  210. zetec crank
  211. zvh oil cooler
  212. nearly ready for the show season. my s2 update
  213. temp sender for 1988 S2
  214. Rear disc conversion
  215. DOES ANYBODY KNOW???
  216. Tailgate Struts
  217. Green Tint RST opening rear quarters?
  218. Step by step guide
  219. TWIN HEAD LIGHTS YES OR NO
  220. Turbo timer advice please
  221. testing tps
  222. ap 4 paddle and standard pressure plate?
  223. 2.1 zvh
  224. series 2 engine prob
  225. Gaz coilover Suspension
  226. is this a big valve head????????? please help!!!!!!!!!!!!!!!
  227. getrag 6 speed box into mk 3 escort
  228. st170 to zvh
  229. wont go over 4000rpm
  230. Locking wheel nut key
  231. which plug to which ecu?
  232. escort cossie wheels with coilovers
  233. s1 -s2 rad
  234. engine number
  235. rear wheel bearing please help!!!!!!!!!!!!!!!!
  236. Oil Cooler
  237. 2.0l zetec rods
  238. FRST Gearbox in to a MK4 Series 2?
  239. bowl of soup
  240. Ever seen this before??????,
  241. yea drove rs first time in2 years plus
  242. got a promblem :( oil cap keeps blwing off
  243. in a predicament???
  244. erst loom
  245. having trouble with plugs and where they go
  246. mk5 turbo exhaust solution..??
  247. squeaking noise passenger wheel
  248. My RS Turbo
  249. will 16" alloys clear my arches
  250. Aftermarket managment issues
