- CVH Baffled Sump...
- ofam and 21psi??
- Actuator Identification Help Needed!
- gearbox oil
- Rusty roof fix...
- Are the rear Chassis rails available for the mk4 escort
- What's needed for 200bhp
- Who's got a zetec turbo with rst manifold
- 380bhp malta rs turbo
- Big brake conversion
- Carbon or fibreglass tailgate for mk4 anyone make them?
- Brakes
- Tuning
- what goes into a 2.0 zvh conversion ?
- Management
- Engine transplant help
- Cosworth throttle body
- Rs turbo Diff how much
- brake callipers, help please
- Electric sunroof, is it possible?
- kind of mega excited got my s1 ;)
- seen an rs turbo for sale
- Tyres
- Why doesn't my rs sound like this
- paddle clutch
- Few Questions
- Zvh starter motor advice
- help plz
- Engine removal
- Is my metering unit piped up wrong??
- CVH Specs....
- Engine question
- hi guys a newbie on board
- Zetec Turbo Head Help !!
- Spot light question :-)
- What are these?
- Fuel Accumulator
- An update on F262 SVW
- Any one had wheel bearings that loosen.. randomly!?
- mk4 rs n xr3i master cylinders the same?
- rs turbo cabs??
- What times did people put in at the pod then!
- New fuel hose... aeroquip? or alternatives?
- rear wheel bearings
- Vibra Technics Cradle mounts 'road' or 'competition'?
- Whats a standard 90 spec series 2 worth the brake ?
- mk1 focus rs wheels will they fit a s1 rs turbo cabby
- XR3I fusebox+loom same as rs turbo?
- 2 yesrs and finally ready for mot
- cosworth exhaust housing
- Rs turbo conversion
- Adjustable cam pulley - any benefit?
- Vaccum hose to Ecu question
- Bonnet Lifters (Hydraulic ones not MDF blocks)
- pod sat/sun
- DEI spark plug boots help !
- How to determine silver top?
- turbo question
- Do all rst's use knock sensors?
- Inlet temps...
- Launch Control MS2
- S1 gearbox won't stay in 3rd, setting up linkage or gearbox??
- ZT Sounds like my dip stick is hitting something?! lol
- A1 rs spares, what they like to deal with?
- headgasket question
- zetec turbo
- S1 Mk3 skirt screw cap covers
- RS Turbo custom inlets
- braided fuel lines
- lost rs turbo
- Rs turbo head the same as any other 1.6 cvh head?
- Fuel filter banjo bolts
- sunroof
- Puma shifter on RS Turbo?
- S1 turbo pulls across road
- s1 hot and cold start
- changing zetec oil pump ?
- launch control on megasquirt
- Another twist
- t3 return pipe?
- Tuners
- Finally have my S2 on the road
- Brake servo
- Mk4 front hub
- Efi fuel pump
- Need a quick answer for wheels guys
- who's got a custom cage's cage?
- a tricky running fault
- Ticking over
- master cylinder/servo options
- C308 MCU
- Screw hole next to petrol filler corroded and fuel tank is loose
- Engine problems s2
- Sunvisor
- S1 engine number location???
- S2 running problem
- get rid of abs
- new S1 inlet complet whats worth
- Flywheel reskimming
- Can anyone shed any light on why this doesnt work?
- turbo shopping.
- Throttle Cable
- Another ABS Question
- need help please
- Sun roof (Roof lining removal?)
- Wiring for gauges ?
- Rear crank oil seal
- Turbo elbow and pipes
- Fuel pump bushes
- Focus rs caliper bracket
- Mondeo 300mm brakes
- seatbelt problem
- s2 turbo exhaust
- Brake bias valves
- Help.... M.o.t booked, 2/4/2012 but....
- S2 zetec turbo water hoses?
- short shifters
- replacing steering rack
- silicone vacuum hose, what size bore to buy?
- Amal valve
- 1.9cvh
- Mercury Grey 90spec front bumper wanted
- Steering Rack Issues
- Has any1 got spring spare
- Rs Turbo Misfiring.. Now Sorted! Fuel Issue Problem Found & Fixed :)
- gearbox ??
- Starting Trouble
- That awkward moment when.....
- Helix road clutch does it need pedal mod?
- whats better
- Helix road clutch pedal mod?
- fan comin on randomly
- MS users - Accel enrichment...?
- delete thanks
- Fuel pump cradle budhes
- anyone cutting up a mk4 escort-panels needed
- 205/50/16 tyres
- just sex fist day out this year!
- 3rd gear running probs help please
- gearbox mount
- Load apportioning valves point of interest
- Is this a good price?
- Sun roof try removal
- Dyno Graph question..
- Escort strut caps
- Wheel Change
- what are rs turbo s2 wheels worth?
- Boost gauge help!
- Heater problem
- anybody raced the 2.5 focus rs in there escort?
- Rs turbo starting problem
- Arrgghhhh - BASTARD ESCORT
- Help...
- Spring 2012 Sale!
- Windscreen washer problem
- RS Turbo MFI Fuel Injector Seals.. Where From??
- S2 kick strips inside the door shuts ?
- how to fit a turbo timer
- RS Turbo S2
- Anyone run rear headrests?
- mk4 escort heated screen relay
- changing fuse box
- anyone breaking a mk4 escy?
- RS turbo fuel tank differences ??
- msd superchip
- camshaft.. what one.
- engine mounts???
- Anyone got a decent fuel pump cradle for sale ?
- Shocks
- To buy or not to buy!
- Water temps
- doing the cutting out thing again?
- Rst on omex hot starting issues
- New fuel tanks?
- Intercooler, Fans, Radiators
- v6 mondeo brakes on a s2????????
- VXR INJECTORS (Again... Sorry)
- No fuel past metering unit and melted relay! help!
- actuator
- mk4 rad
- Help again pls
- Changing Turbo
- knocking noise while driving??
- Oil pressure switch leaking
- Most Expensive RST for sale in the UK ????
- brakes still spongy after rear caliper bleed?
- dealer on drugs ????????
- Wheel size? 16 or 17??
- rs turbo no oil pressure light
- what clutch
- Any body know if these are worth buying?
- Cosworth wheels
- Series 2 polybushes???
- newman cam nocking when cold?
- hybrid fitting
- i need a backbox
- Does anyone make rear link kits for the RS anymore?
- newman cams ?
- under bonnet thingy!
- radiator to use on a escort rst s2?
- 88spec roof lining query?
- Clutch pedal removal
- dump valve
- Front bumper cold air feed
- mk4 hubs
- which injectors?
- i need to find a tuner to chip my s2 rst anyone?
- Rs turbo H2 LGC
- front speakers
- On Going Headache Intercooler/Radiator
- S2 Tuners...
- coilover help
- What Thread
- water injection setups
- Which ecu?
- Fans wont come on
- my rs
- efi fuel tank?
- rst bearings
- best way to clean intercooler and samco hoses.
- painint rocker cover!
- yard find
- no spark on coil
- rear wheel movement
- which clutch
- omex 600 or megasquirt?
- backfire under load
- Schoolboy error....
- In need of direction advise
- Kent can 32k cvh
- Speaker toggle
- Engine oil
- Need someone to measure
- Escort Stalls When Warm While Driving
- Best front mount to use with t3 turbo on my s2 escort rest
- Running slightly off?!?!
- what to do?
- One For Megasquirt Bods...
- Rebuild
- New rads on fleabay
- Batt light.
- Standard arch pictures please
- dyno in the morning
- Brake Lines
- Zetec turbo pistons?
- 195/45 or 205/40?
- Finally picked up the battleship :) (Now with Leda's and white FR's)
- Boost hoses
- FRST fuel rail
