launch control on megasquirt
have any of you guys running megasquirt tried it and if so could you post a screen shot of your settings if poss to speed up the process for me if not i'll do the trial and error route
Here you go mate,
Still haven't found a base map that would be any good for yours but i do have some launch settings![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
![](http://i68.photobucket.com/albums/i6/Rob_DOHC/launch.jpg)
Other setups i have seen run a low as 1deg advance and have a lower rev limit. I found this worked well but was very harsh, so backed it off to 3deg and have a slightly higher rev limit due to the sticky tyres i was running. On normal road tyres i would go for a lower rev limit, or retard the timing less, or pull fewer sparks. This will limit the boost made on launch but also help with traction.
Launch control is good fun![](https://passionford.com/forum/images/smilies/roi.gif)
Rob,
Rob,
cheers rob and yes your right my input is js4 but gives me some values to start with, think my neighbours are going to love me this week while i set this my nos and antilag just hope they look at it and think what an old banger won't even run right it's backfiring like mad
Balls Deep!
Yeah all good! Running about a 14psi at the moment (dont think the .48/60 will flow much more TBH), feels about as quick as my CVH did at 30psi (around 270bhp) but have literally only spent 45mins mapping to just make sure it's safe!
Much more responsive and so much quieter than the CVH too, engine itself that is not the exhuast note as that sounds exactly as it did before!
Sweeet sounds like its all going well Karlos! Have a play with the TPS value Rick, I kept it quite low as you can use the throttle to adjust severity, with the throttle backed off mine was making 5psi boost, planted it made over 10 but it did sound very violent lol!
Rob,
Rob,
