- Side skirt and widekit mounting for RS turbo
- Engine Convertion. 2.1 ZVH
- Adjusting linkage sticky???
- f1 cups and s1 arches
- junking ABS
- Anybody got any pics of a bladed antiroll bar setup for a ERST?
- fuel pressure
- HELP! setting gear linkage
- Just been to look at a s1
- Looking for CVH quality lifters...
- wot oil do you guys use?
- Zetec turbo breather help edit: more pics
- What Clutch????
- RS Turbo running on 3 cylinders?
- whats it all worth???
- S2 On A Classic Policy
- dashboard swap
- think ive had enough
- Breather Venting Help MFi
- Will i need a plate for my exhaust?
- where can i get....
- System 2 1.9 Power Engineering
- wipers wont work.
- car setup
- Freeing seized clutch - S2 RS Turbo
- Why is there a gap on my side skirts?
- S1 Ecu On To A S2
- why is my camber so out?????
- plastic windows
- Gearboxes
- using turbo diesel gearbox
- which exhaust makes more noise??
- 90 spec h plate rs turbo
- sunroof runners & efi clocks around norfolk/suffolk
- poor idle and stalling
- I hate fords!!!
- Fucking car!!!!!!!!!!!
- Im leaving the RS Scene :-(
- s2 keeps throwing out of gear
- Cosworth Managed Escort Turbos
- missfires
- Anyone else got something 'not working'??
- indercators
- temp gauge stop working?
- identifying a 1900 block
- Charge carrier advice
- pop out windows s2
- Cheapest place to buy powerflex full kit for S2 turbo?
- anyone got escort front screen laying about?
- rs turbo rear roll bar
- heater and fan not workin
- Rattles???????
- Rolling Road Tune, or actually rolling car
- Air Filter Help Needed
- escort mk4 lowering springs??????
- bigger brakes - whats can go on?
- anyone got an rst rocker cover they dnt want
- Oil leak.
- Lockable aluminium fuel cap
- Temp Gauge goes up when I turn the lights on!!
- Cosworth management question. I del control valve not plugged in?
- Series 1 Front tie bar
- MK4 rs turbo handles and xr31
- EvolutionChip how many Psi
- roll cage for series 2
- Priming an oil pump
- Focus Smell
- turbo spluttering and back firing ?????
- Im New So Dont Hurt Me
- how much for 2.1 engine?
- Gmax suspension kit
- Snap off boss
- MFi injectors reference?
- how do you make a mk4 handle?
- Where to buy a distributor?
- best suspension ?????
- Safety Devices Rollcage.....
- high idle
- EFI conversion price
- Dirty Great Misfire! PLs Help
- S1 no spark, help!
- xr3i mk4 efi loom with ecu wanted
- efi parts
- Doubt About Rst S1 Metering Head On Rst S2
- some pic's of my series 1 cab !
- s2 rs turbo
- s2 rs turbo suspension
- series 1 idling problems
- ignition lock
- hpw to adjust thefuel on a s2 mfi
- miltek exhaust for rs turbo?
- Quick question
- I have a problem!
- Cosworth interior fit an ERST?
- fao those with 1.8 zvh..
- escort xr3i efi to rs turbo
- spark plug gaps cvh
- radiator problems
- series 1 ecu on series 2
- zetec torque settings mains?
- At last.....
- misfire
- Brake issue
- Escort repair panels.....
- Cant Decide help lol
- speaker sizes....sorry
- s2 side skirt and arch fittings
- how to fit a mk6 escort sunroof in ur RST
- Relocating brake pipes
- Cant get hub nut off!!!
- Uprated loom for s2?
- help how do i tell a lsd gearbox
- anyone got a metering head that works (cash waiting)
- coming to England maybe want to see some RS's
- Mk5 sunroof fits s2????
- Still Looking.........
- MFi CVH to ZVH conversion help.
- speedo needle wobbles
- Woooo It Works!!!!!!!
- s1 leg and s2 legs same help please
- Why an RST?
- s2 reg F200 TAB
- rain gutters
- rs stearing wheel
- So what Shocks/Springs are everyone on??? - Add pics!
- ignition lead order
- Dont think my engine is running on all four
- Mains Bearings
- buying an rs turbo
- gear box for 200 brake s2
- white smoke rs turbo
- Anyone Got Megasquirt Base map for Esc S1 turbo
- Where to get a Leather Gaiter for Gearbox?
- any1 know where to get a starter motor heatshield?????
- polybushed engine and gearbox mounts?
- RS broke doen today!!!
- will they fit????
- New Shell...
- grinding noise on left hand bends
- mk3 carbon bonnet?
- what to do
- how to tell a proper 90-spec car?
- Ford Cam spec's for CVH.
- smoking !!!! valve stem oil seals ?
- HELP!!!! What The F**K????????
- Towing eye cover question. . .
- Stage 3 Head Conversion?
- 1300 bonus engine swap
- drive shaft
- Actuators and Door Cards???!!!!
- Clutch Problem
- advice please going to take my s2 engine out
- 15" steels
- clutch options
- efi conversion
- efi conversion
- rs breakers in midlands
- what bits to keep??....
- offside hub
- carbon roof skins ?
- s1 arches on my s2 whats ur thoughts ????????
- Wheels
- Fuel Metering Screwe Erst.
- turbo choice
- Advice Before Start Fitting B&M QUICKSHIFT
- why....
- eRsT settin up??
- What clutch is this . . .
- does a s1 gb fit a s2?
- Best place to put oilcooler
- gettin there now
- newb, some help please
- Hose Size for Amal Valve
- pics of my S2 at ford fair its first show
- Loud tapping from head and deeper exhaust note.
- is there a guide for an rear brake conversion at all?
- stunning s1 ND anyone on here
- g plate series 1
- 1.6 CVH Oil Pump - Ford or Burtons?
- indicators not working?
- Spotted Red S2 F Reg' A12 Colchester today
- any one know series 1 ? reg b209byb
- Series 2 Engine Rebuild
- Max boost for Series 1 stadard Engine, IC, and Turbo?
- rst wont start
- 1.6cvh into 1.8 escort
- New Vin Plate ???????
- RS still misfires after changng everything
- rs turbo fuel regulator
- T34 swap..
- zetec turbo piston and rod choice.
- rs7 spokes on series one
- loom colours.
- Engine choices
- northwest england
- EFI - MFI
- Turbo pipes help!!???
- Suspension kit for the S2
- efi ported head
- Where does the sunroof drain into?
- RS500 spark plugs in cvh
- 3rd gear sumtimes wierd
- A Pillar Trim Problem
- S2 RST, engine tune to 200bhp
- a few pics of my new s2
- zetec turbo (blacktop) water pump solution
- oh what to do!?.....
- D reg S1 on e-bay
- Oil for Escort RST
- exhaust heat wrap
- fans
- gotec or megasquirt?
- rs turbo lower arms
- Best Newman Hydraulic profile
- mk3 escort cabriolet se spec ???
- S2 GAUGES
- flashin oil light
- Bleed valve probs
- what's a 2.1 zetec turbo worth?
- Top water hose, internal size?
- low compression pistons
- Biggestbrakes To Fit Under Rs7 Spokes
- Power Engineering "System Two" 1900 blocks
- AreoCatch
- Bigger wheels lighter steering??
- what do i need for a 2.1 zetec conversion?
- kent cams
- Cant Get My Rst To Start
- rst running cosworth managenment
- master cylinder
- hazard flashers playing up
- 5 injector ore cold start valve
- boost problem
- rear disk conversion, brake bias valve?
- RS misfires changed everything
- spacer plates?
- PACE intercooler
- mfi chatters!!!!
- ABS to non ABS legalitys
- Manifold/Servo connection WANTED!
- Throttle Cable EFI
- easy to fit rear wheel bearings?
- Wheel size - offset etc Esc S2??
- how much is chipped ecu worth?
- Fuel line removal
- s2 help please
- boost limiter
- S1 interior floor paint.
- Camshaft problems
