Zetec turbo breather help edit: more pics
EDIT : https://passionford.com/forum/general-car-related-discussion/259679-my-friends-zt-fiesta.html
Asking for a friend, just finished building his Zetec turbo, all running, just needs running in.
Spec is
Silvertop 2.0
GT28rs
Steel rods
Forged pistons, unaware of compression ratio
803's
Autronic
Standard head/cams
Tubular manifold
Custom inlet / Cossie TB
17psi
Now, theres no breather fitted at the moment, any suggestions or advice please?
Picture..
Spec is
Silvertop 2.0
GT28rs
Steel rods
803's
Autronic
Standard head/cams
Tubular manifold
17psi
Picture..
Lukesville
This is my oil breather/catch tank.
This has outlets on the left top corner to the cam cover one in use one blanked for future.
Then the top front face has a push fit for the oil breather filter
then we have the lower threaded fitting which is drain to sump the other fitting is the link to the lower oil breather on block (pictured below)
Looking great there Radders
With that exhaust manifold there should be plenty space for your mate to use the breather hole on the front of the block, and pipe that and the breather from the rocker cover up to an oil catch tank.
