zetec turbo (blacktop) water pump solution
Its actually an st170 engine but same size hole!?
Fit electric pump?
Some sort of pulley to change the direction and use the standard st 170 pump?
machine the block to take the older zetec escort/fiest pump?
any ideas people must have come accross this same problem?
Fit electric pump?
or you could just run the standard pump with a simple pulley,thats all i do and mine is a st170 turbo in a mk3 fiesta
A little off topic , but does the pump of the silvertop go the right way'? as i'm planning on doing a zvh-->zetec conversion with a silvertop engine
it basically just a bit of angle iron with 4 8.5mm holes and a slot with the rear auxiliary belt pulley off a focus/mondeo on it and a 1150mm belt and the cvh alternator with the zetec wheel on it and cvh bracket
