Throttle Cable EFI
If i have normal escort rs turbo with efi intake manifold +throttle housing what parts i need to make it work? Now i have rs turbo standard throttle cable cutted with locknut in the housing.
It works but it is not that good it should be.
use pedal off a mk3/4 carb and cable off a escort mk5 efi carb will fit straight on to efi t/b easyer to find than 3i efi stuff
I think i will just botch the std cable for now, it's only to test all the fuel injection componets work properly before i put a 2.3 in.
I bought a new xr3i throttle cable from fords about a month ago so i know they still sell them. Unfortunatly i cant find the part number. Just thought i would mention that the throttle cable clip that secures the cable to the inlet manifold is sold seperately. And by the way that cable on ebay is the right one but a rip off!!!! cheaper if you go to mr ford
Everyone seems to get mixed information from ford. I know i bought one as i have it on my car. Ill try and find the fins code so it might help some ppl out.
Now i use rs turbo standard mfi throttle cable, but it is quite short for it.
If i buy escort efi cable, i have to change the accelerator pedal.. where can i grap one? There is nothing on ebay at the moment, how about ford still available and the price?
I think the cable is the easy bit - motorfactos will have them for a couple of quid (1600 zetec)
Need to find a pedal. If it's same as a carb, should be ok.
Called for local Ford today.
xr3i escort efi cable discontinued, and same thing with the pedal.
1.6 zetec cable and carburettor pedal should fit if i am correct, used forum search earlier.
I bought today pedal from the scrapyard, it is from carburettor cvh engine.
I went my garage and look down in my rs turbo pedal, i think they are same?
Confused.
If the one you got from the scrap yard has a ball joint on the end its the wrong one. The one you need has a tag with a slotted hole in the end.
if you have the cable thereis a simple soloution, make up another plate with a solt and hole in it then drill/rivit it to your exsisting pedal, the time its taken you searching for one you could of made one!
Yeah.. i did find one today, the car was laser escort.
There was no engine any more but the pedal was correct
3Ł was price at the local scrapyard
Here i have parts and i did install them.
Everything fit nice..
http://3.bp.blogspot.com/_-EspJygF5l...082008+086.jpg
-Pedal from laser escort ( dont know year and engine because it was smashed one but i think late 89-90 and carburettor.
-Clip from efi manifold
-Ford escort MK5 Zetec 1.6 throttle cable
Bit of a thread bump but the XR3i Efi cable is still available from Ford (bought one today) 2 years on from this thread contrary to a few posts on here saying it was discontinued, including someone who was told by Ford lol
The part number is 9C799, FINIS code 6617342
Under 20 quid too
Under 20 quid too
mk3ste
17-10-2021 10:09 AM
muz
30-09-2015 08:29 AM
