wot oil do you guys use?
hi, just wondering wot engine oil/grade, you guys use/recommend in your rs turbo,s also wot make of tappets you are useing as every set i buy seem to rattle there heads off after a few months!! lol.
miller oil 10/60 and cam and tappet combo of different sources, if you keep knackering up tappets are you swapping cam/tappets or just tappets and when doing both make sure you use plenty of lubricant and keep revs over 1500 for first 15 mins
Cant go wrong with mobil 1 motorsport, as mentioned you have to change the cam and followers together and if you still get major wear sounds like you have a oil pressure problem.
My power engineering cam has been in 9 years and still dont tick hardly at all
S1 Database Editor
I use vauxhall semi-synth. The two garage I go with my two cars both use this oil. One place is a Ford and RS nut and has many years experience with the RS range. He did a comparison check on the qualities of the vaux oil & the other major labels and found they are similar - except the vaux oil is a lot cheaper (around £15 for 5 litres) as they don't have the branding & advertising to contend with.
Been using this for around 5 or 6 yrs now with no issues what-so-ever. Best thing is, as it's cheaper overall, you can do earlier oil changes for the same money.
Latest poll I did on my site came back with semi-synth 5 or 10W.
Mobil 1 was considered too thin unless it's a new build engine.
Hope this following info is of use:
My vaux oil is 10W/40 Semi-synth. Oil properties are ACEA A3, B3, API SL/CF
Properties description found via here:
Oil Bible
ACEA are here European Car Manufacturers Association
codes relate to
A3 = high performance or extended drain
B3 = high performance or extended drain
API are these people API which seem what thatcham are to alarms.
So the SL/CF rating is S= Petrol car, L = the top grade (SL = old lettering, recently replaced with SM)
CF means it can be used on commercial vehicles also
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
