Focus st170 rear brake setup
I'm after the above rear setup what would I be looking to pay for this, hubs calipers, dust covers, carriers thanks
And has anyone fitted these to a escort mk6 I need to know what is required to fit the handbrake cable thanks in advance
Mate:
Your looking anywhere from £80 (Lucky) to £200 for the set up above.
Ide just buy some Focus Ghia 2.0 16v rear set up 250mm (ST150 is the same)
£20 a side from a scrappy .. Take a Sthil saw.
The only difference is the Caliper carrier, Disc & Backing plate.
The other parts required (Non ABS) Is Puma 1.7 16v front Hose & Any Mk1 Focus disc handbrake cable (Rear) You can re-use the Original but might as well do it proper.
yeah ive already got the front puma 1.7 hoses lol ive heard somthing to do with having to modifiy the handbrake to fit thats all im unsure on tbh and finding a set of st170 set up thanks, paul
I got this done by pumabuild on my old Mk6 escort and it looked spot on ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Here is a picture guide I made up of them doing the job if it helps you out http://www.sportingfords.com/forums/....php?f=16&t=25
yeah good read do you know how they modded the handbrake cable or what it actually needed modding to do
I think they just had to grind a bit away out of the metal bracket on the handbrake cable so it fit in place, like a half moon type shape out of it if thats any help?
Hopefully someone else more mechanically minded can shed some more light on it maybe?
![](https://passionford.com/forum/images/smilies/smile011.gif)
