Focus ST170 Rear Caliper Rewind Tool
Old 21-08-2010, 01:46 PM
MattEMUlsion
MattEMUlsion's Avatar
Default Focus ST170 Rear Caliper Rewind Tool
Can anyone recommend a particular brake caliper rewinding tool that will fit the calipers on the rear of my Focus ST170? I want to make sure that whichever one I buy will fit okay as the choice out there is quite large. A lot of them seem to come with only a single (double sided) adapter which does a large proportion of cars, but will one of these be suitable for my calipers. Has anyone got any experience of what fits and what doesn't?
Old 21-08-2010, 06:28 PM
3DOOR ARY
3DOOR ARY's Avatar
I put some new rear pads in my FRS yesterday,long nose pliers worked fine for me,also used them on my old 3dr callipers
Ary
Old 26-08-2010, 09:18 PM
JamesR1
Anybody for a brew?
JamesR1's Avatar
if i dont want to spend on snap on i ternd to use sealy. there decent quality.
Old 27-08-2010, 09:43 PM
phil_focus
phil_focus's Avatar
pair of needle nose pliers work for me, can be a right bitch to get them started though!!!
Old 27-08-2010, 11:52 PM
.Ross.
.Ross.'s Avatar
Aye ... Both Calipers wind in the same direction so no pissing about ..
I use a Derd cheap Motor-Factor shop type tool and it works a treat ..
Old 28-08-2010, 10:28 AM
TomEbbs
TomEbbs's Avatar
Or an angle grinder disk removal tool also works....
Old 28-08-2010, 04:06 PM
I used either a laser or draper one, double sided pin bit as you say, got it from wilco, if much prefer this to the pliers etc.
Old 28-08-2010, 04:18 PM
.Ross.
.Ross.'s Avatar
Pic for Prosperity ..
Make sure you line the Groves up with the tit on the pads.
Old 11-09-2010, 03:26 PM
MattEMUlsion
Just to conclude this topic I ended up borrowing a rewind tool and it made the job a doddle. For future reference the basic Laser Tools (1314) rewinding device fits the ST170 rear calipers just fine.
Old 11-09-2010, 04:45 PM
focusv8
focusv8's Avatar
And also for reference the Standard Focus, S.T and R.S all use the same rear caliper. It's only the disc and mounting bracket that change.
james kiely
28-08-2015 08:58 PM
Palethorpe01
15
18-08-2015 06:09 AM
track.focus'd
12-08-2015 05:53 PM
gordyshreds
20
10-08-2015 02:59 PM
Quick Reply: Focus ST170 Rear Caliper Rewind Tool
