PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. mocal oil cooler 25 quid
  2. 6 paddel clutch
  3. Ecu Chip Identification help needed
  4. Identifying my gearbox - help please !!
  5. mk4 Glassfibre boot
  6. how low did you go
  7. s2 door mirrors help needed
  8. has anyone got a pic of where all the water hoses go?
  9. Glad I took that to bits.
  10. Are T34's a direct fit?
  11. Sunroof problems
  12. Just killed my T3!! UPDATE - Not a snapped shaft! Pics!
  13. Anyone know this car ??
  14. modified front ends
  15. S1 and S2 gearboxes
  16. max bhp without a chip??
  17. What brake pads produce least dust??
  18. Clutch cable
  19. Boost creep?
  20. Clutch release bearing - Help !!
  21. cossie 4x4 t3 on standerd'ish cvh
  22. Change rims ? [pics ]
  23. clutch
  24. Paint
  25. Efi inlet manifold
  26. chipping my s2
  27. superchipped ecu
  28. cvh block breather baffle
  29. rst clocks?
  30. is it posible to run two seperate intercoolers
  31. New oil sump !!
  32. s1 rs turbo cabriolet zvh project for sale for s2 rs turbo cabriolet
  33. s1 stripes on a series 2
  34. Mfi setup question
  35. Help needed Non starter s2
  36. Spark Plugs
  37. Anyone know the Gap Settings for Solid Lifters ???
  38. convert my 1.6 rst efi to 2.1 zvh
  39. Hi what bhp should i expect from this setup
  40. Maybe for the Fiesta Turbo Room?
  41. Replacement mk4 panels……..
  42. MTX75 Gearbox Fitting guide into mk3/4
  43. FUC*ING SUMP GASKET!!!! help!
  44. rear roll bar (help!!!)
  45. new wheels
  46. Can you get a genuine 300bhp from a 1.6cvh
  47. Spotlights - Carello 640 ?
  48. valve springs and valves
  49. Running in a Newmans cam - how do you do yours?
  50. Cold start problem
  51. 8x16 et30's on a s2
  52. Troubles
  53. Wouyld this gearbox fit?
  54. ZVH oil pressure
  55. Flamer kit?
  56. Clutch help please
  57. compresion
  58. S2 engine bay pictures
  59. Cvh weight
  60. mfi injectors
  61. What size tyres on 16's??
  62. cheapest place to buy standard piston rings for s2 rst?
  63. do water pumps rattle??
  64. Decent exhaust clamps
  65. Extreme price difference?!
  66. Stud conversion.
  67. Which head gasket ??
  68. conections for the 941 pump ?
  69. high compression VS low compression
  70. carellos
  71. Fuel relay??
  72. Front suspension strut top rubber boot cover
  73. sterring problem after new wheels change ( pics inside)
  74. Kent camshaft cvh 35
  75. Odd one for ya d/v
  76. MFI Adjusting the fueling.
  77. Leaking Wing Mirror
  78. Bottom end build
  79. HIDs
  80. ERST fuel flow sensor......
  81. seat sag
  82. air filter pipe?????
  83. whats the best clutch for a rs turbo s2??
  84. Escort RS Turbo fuel metering unit
  85. refitting clutch cable
  86. Twin Turbo??
  87. modifying a mfi inlet manifold
  88. K & N or Pipercross
  89. opinion THS H-beam conrods
  90. Mk3 Arches on Mk4?
  91. best upgrade IC and radiator for S2
  92. advice (picts inside) bottom end/head - also is the head ported?
  93. gear linkage pic request
  94. Spongy brakes..HELP!!
  95. MSD fan switch temps???
  96. coolant
  97. Heard alot of opinions on injectors..
  98. Engine wont start after having fuel injectors cleaned!
  99. efi head on mfi block
  100. pair of fiesta turbo seats and turbo starter
  101. series one guys
  102. Any ideas
  103. zvh question
  104. Strange Noise ?
  105. How do I test my gauges?
  106. changing my engine
  107. does a rwd cossie turbo bolt straight into rs turbo!!!
  108. MegaSquirt & loom cutting
  109. ofab air temp sensor?
  110. fiesta turbo and zvh wat injectors
  111. Efi and crank case breathers.....
  112. Timing advice
  113. Best place for
  114. Oil pressure problem...Help!!!
  115. HELP!!!!!!!
  116. Respray
  117. Help and advice
  118. Best turbo for my rs
  119. rear discs conversion, bled 3 times and still spongey?????
  120. Inline brake bias
  121. escort cossie rims on a s2
  122. Rare s2 factory upgrade
  123. new to this section
  124. After saying never again, i am getting another
  125. fuel pressure actuator
  126. a couple of s1 questions
  127. escort mk 3 - mk 4 connectors ...
  128. group A headgasket
  129. metering unit
  130. No Boost...
  131. bhp?
  132. Is it worth getting a stage 3 head?`
  133. starting problem ..please help
  134. bailey dump valve not working!!!!
  135. metering unit problem
  136. s2 arb bracket
  137. oil cap seals
  138. EFI coversion
  139. rs turbo stalls when cooling fan comes on
  140. rs turbo jerking help needed
  141. spoiler
  142. Massive favour needed
  143. help needed
  144. Radiator
  145. New to Rs Turbos HELP PLEASE
  146. Brake bias valve
  147. fuel relay can i get rid off it? or can i bypass it, it keeps melting and cutting out
  148. S1 ARB on a S2, anyone done it?
  149. reconditioned t4 turbo prices and places
  150. oil pressure gauge
  151. smoked rear lights ?
  152. top radiator hose
  153. whats it worth?
  154. t3 castings
  155. removing exteria door trim off xr3i question
  156. EFi Fuel Pressure
  157. Zetec turbo build questions
  158. CVH cam.
  159. whos running a piper cam?
  160. cheap copy turbos of ebay stage 3 hybrid any good or not
  161. Breather system help
  162. will escort mk4 bumpers fit a escort mk3
  163. steering colum bushes s2 ???
  164. Remap the chip for every different cam
  165. mfi rs turbo chatter
  166. One for the Euro boys... Bonnet Bra's!?
  167. Left hand drive throttle cable for rst s2
  168. rst had its first run today since rebuild
  169. ST170 6 Speed box in s1...
  170. Xr3i cabby to rs turbo
  171. for those on aftermarket management
  172. Followers
  173. in need of a series 1 fuel tank!!
  174. metering unit
  175. For those of you running anti-lag/Launch control
  176. Kent cam
  177. RST/3i Roll bar question
  178. rs turbo lambda sencer
  179. fan upgrade
  180. Had a really lucky escape
  181. Which zetec starter motor?
  182. Black interiors
  183. Electric windows and all sorts of dodgy electricals
  184. are they the same?
  185. Best Front Brake Setup?
  186. what should co be on a s2
  187. fitting bodykit, re drilling sills and arches?
  188. where to get omex mapped/checked in the midlands ???
  189. Mahle or forged pistons
  190. Gearbox re build
  191. dash lights
  192. HELP info required
  193. zvh rebuild time
  194. Battery Spec.
  195. Help fixing a rear seat.
  196. REV counter help
  197. escort 2.1 zvh
  198. more fuel
  199. EFI conversion
  200. brake hoses for 4 pot upgrade
  201. buzzing
  202. Ford Escort RS Turbo Resto
  203. grs fitting?
  204. Engine Rebuild time :(
  205. s1 turbo same as s2?
  206. speedo cable gearbox oil leak
  207. Strange noise on boost
  208. escort mk4 speedo / clocks
  209. Turbo gasket
  210. Help Metering Unit Needed
  211. Removing rear antiroll bar
  212. How hard is it to change a turbo DIY
  213. Help Wont Start
  214. Blower Relocation?
  215. Opening rear quarters on S2
  216. sump plug
  217. whats this?
  218. Rear strut brace question
  219. clutch
  220. Series 2 Rear lights
  221. escot rs 1900i
  222. Cosworth brake set up, which braided brake lines?
  223. front suspension question?
  224. newbie here.... need help with my s2 knocking noise
  225. 88 Spec Front Seats
  226. favorite s2 rs turbo !!!!!
  227. What is a t34?
  228. s2 power to weight???//
  229. Rs turbo boooost
  230. may be selling my s2 d reg good con
  231. Engine fuel Cut help :-(
  232. Powercord from enginebay to boot?
  233. rs2 speaker size?
  234. Headlights come on when brakes are applied....help!
  235. s2 inlet to xr3i
  236. gearbox help
  237. ofab using cossie 3 bar map sensor?
  238. Turbo
  239. Edis or internal driver?
  240. braided brake hoses to rear calipers
  241. series 1 bits
  242. gear linkage rebuild kit?
  243. rs turbo parts
  244. oil pressure warning light. help!
  245. rs turbo conversion
  246. Cant find any mud flaps?
  247. information on series 1
  248. Fuse box removel
  249. pipe from ecu??
  250. Escort RS turbo roof.......
