rs turbo jerking help needed
when driving along in every gear the car starts jerking realy bad,its been doin this for awhile now,ive changed gearbox,clutch,clutch cable,gearbox and engine mount,ignition leads,and its still doing it,there is a good spark from all four spark plugs,any ideas on what else this could be?
yeah mate fuel to each cylinder,and good spark on all four,leads all correct,and timing top dead centre, its doing my head in now
its all new mate,was running fine then taken it off road for winter,when put back on road it started happening,the jerkin is that bad it makes the gears pop out in 5th,so i tryed a new gearbox and still the same,the only other thing it dos is backfire a bit on boost,
me and my SB!!!!!
what set up are you running mate if your ECU is standard and your runing over 0.8 ish boost then your ECU wont be giving enough fuel.
the ecu is chipped mate,and only running 12psi,it was sound at one point then when got it out of storage got all the juddering problems,ive just found out that the throttle postion senser is no good but not sure if this will cause the jerking? and also theres a air leak sound coming from around the inlet manifold,could this cause poor running?
me and my SB!!!!!
ive just tightened the inlet manifold nuts up,and the air leak sound as got louder and taken car for short little drive and the jerking as got worse,so i imagine this is the problem! goin to get new gasket! hope this solves it
me and my SB!!!!!
sounds like it to me mate,let me know how you get on though,fingers crossed.
get it booked in some where for a set up mate could be a number of thing making it do this boost/fuel/air leak maybe a few thing together making it do this, i have heard of a few rst that was runnig fine on mfi took them off the road over winter and when they came back out they was running like a bag of sh!t
soon as sorted air leak out mate ill be gettin it set up! got a new throttle postion senser coming tomorrow,and putting new gasket on,cheers for the advice jamie.
ive not ad time to put the new gasket on today so dont now if it is the gasket,i dont think the fuel system is blocked or got dirt in it because ive taken each injector out and each one is flowing fine,me mate sorted me a tps for free and got the new gasket for £4 so if is the problem,cheap and easy fix! lets hope so,
big_Rad
15-09-2017 09:36 AM
muz
16-08-2015 12:57 PM
