MegaSquirt & loom cutting
Old 10-05-2011, 08:43 PM
Red_bull
Red_bull's Avatar
Default MegaSquirt & loom cutting
Hello guys,
I'm working on my project EFI engine running megasquirt. I have a original MFI loom in the car. I was thinking about cutting all the crap that i don't use.
What did you guys do?
I was thinking about only leaving the lights and the watertemp sensor that controls the fan. Which of the watertemp sensors controls the fan? There are lots of temp sensors On the right of the head; After the thermostat and i believe there are also sensors on the rear of the block.
Does anybody have an electronic schematic of the ECU? I think i have some in my haynes manual, but probably not the ECU controls.
Can you remove the old ECU? Or is fan control is in the original ECU?
Cheers! I hope for some nice reactions. I'm going to start with it on friday
Old 10-05-2011, 09:02 PM
luke19790_3
luke19790_3's Avatar
fan switch controls the fan. i removed all the wires from the mfi setup including the ecu. just cut a wire at a time.
Old 10-05-2011, 09:14 PM
Red_bull
Red_bull's Avatar
Which one is the fan switch? Blue one after thermostat?
Old 11-05-2011, 07:31 AM
chaffe
Turbocharging Technician
chaffe's Avatar
the one with the heavy gauge wires running through it from the fan. If you are going efi then all the other no longer required stuff will be very apparent, the coolant temp sensor for the gauge is the very small 1/8" NPT sensor in the head.
Old 11-05-2011, 09:04 AM
Rob_DOHC
Rob_DOHC's Avatar
I found it pretty straight forward.
Unwrap the whole engine bay loom, using cable ties as you go (to keep the shape and branch lengths), then cut off the two ecu connectors, then pull the wires out.
A lot of the wires loop the two ecu's together, some go back to the fuse box and the others go to the two relays under the dash (ignition and fuel?).
Work on the basis that you don't need any wires from the ecu's. I also removed my fan wiring as my megasquirt is going to control my fans.
Then when all the ecu wiring is out the way and everything is insulated properly, shove the battery back in and test your lights etc, if its all okay then re wrap your loom.
Job jobbed.
Rob,
Old 11-05-2011, 11:33 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
I would remove the whole loom and fit a non injection loom.
Then you will have no extra wires to cut out and destroy your MFi loom, which can be sold for decent money now days due to how hard they are to find.... because people are going round cutting them up for no reason.
Old 11-05-2011, 12:46 PM
Rob_DOHC
Rob_DOHC's Avatar
Lol, how much do they go for?
i was happy to cut mine up this time round, because i could braid it all nicely. But next time i'd just make a whole new loom from scratch.
Rob,
Old 11-05-2011, 01:16 PM
zippyobrien
zippyobrien's Avatar
With mine I've fitted a base model car loom, that literally onlu has the lights and wipers on it.
Then am going to make a new engine loom to suit the ecu.
Old 11-05-2011, 06:07 PM
Red_bull
Red_bull's Avatar
So most of you have the std dails still in?
Cheers for the recations
Old 11-05-2011, 10:48 PM
Rob_DOHC
Rob_DOHC's Avatar
Sorry, not sure what dails are
Old 12-05-2011, 06:24 AM
chaffe
chaffe's Avatar
The EFI loom isn't 100 perfect for megasquirt so would need unwrapping and fettling any how and at the end of the day they have been in a hot engine bay for 20years....
Rob,
plus i would want to replace as much of the crap ford wiring as possible, its always brown and foosty looking, can cause all sorts of probs
Old 17-05-2013, 11:11 PM
Red_bull
Red_bull's Avatar
Just looking back through some old topics of me and i meant dials Rob. Sorry for that so the dial pod of the dashboard. English isn't my native language, so i struggle sometimes!
Old 19-05-2013, 09:59 PM
Rob_DOHC
Rob_DOHC's Avatar
Haha, no worries mate. Your written English is probably better than 90% of the people in the UK so I wouldn't feel too bad
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
muz
30-09-2015 08:29 AM
Quick Reply: MegaSquirt & loom cutting
