- Help many probs!
- intercooler
- diamonds
- dv take off
- who saw me
- Tapping - Knocking??
- insurance?
- Series 1 - changed ECU???
- 5th injector
- springs,
- wiring loom help needed!
- Front suspension/steering questions!
- S2 better than a escos!
- how easy is...................
- fitting new oil sump..
- what to look for and opinions
- WHERE ARE THEY NOW........
- anybody know this s1?
- quarter times
- Starter motor
- Zetec turbo options....
- Is it possible?
- batt light
- T28 on a RST
- S1 problem . . .
- Hard to get in and out of gear!
- mk6 clutch pedal conversion parts
- Wot's Better????
- turbo
- has this been chipped???
- oil probs, few q's
- points removed from licence!! yey
- weak spark
- My newish RST!!!
- MERCURY GREY S1 ON EBAY
- boot release
- Boost controller or Amal Valve
- s1 ecu
- Oil light
- 2 litre 16valve zetec turbo conversion(help)!!!!
- S1 fuel problem
- help!need someone to collect my car and rebuild it! derby
- u think what i think?
- CLICK CLICK
- short shifter
- Fuel pump is getting 12V & is earthed - yet wont work
- MOBILE SPEED CAMERAS
- Metring head Removal. URGENT
- my smoke prob
- gear box
- where does this plug connect to??
- S1 washer bottle rubber seal wanted
- Smoke out of exhaust
- Fitting Track control arms....easy method!
- K&N 57i/Standard Airbox
- pop bang and flames
- escos alloys on S2 what tyres?
- urgently required!!!!!!!!!!!!
- rs turbo over heating problem
- My S2
- oil coming OUT of oil filler cap...
- zvh question
- Chassis Rails
- anyone help me out?
- Best place to get an Earth on the block?
- SmOkInG s2
- 2.1 zvhz
- car startup probs
- Car alarm!
- My car has turned against me
- fao, the guy to buy the quickshift kit from
- brandshatch trackday!!! !!Wow!!
- bonnet release
- S2 Escort RS turbo flywheel.... help
- Black Diamond discs and pads are great
- Any body got a cossie cooler on there s2
- rs turbo back lights.
- heater matrix
- Another boost problem
- Dawes devices basic boost controller
- air leak on series 2 (need help please)
- need a little help please peeps
- Anyone Know If These Are S2 Gearboxes
- Hmmmm....boost going weird??
- Best place to get spares
- best alloy rad and stuff
- Boost Problem
- Drivers Sideskirt....
- Picture request of a S1 part
- turbo selection
- quick shift assembly complete?
- fuel filter
- Headlight duct
- FAO f525jur and grimmerst! Videos of u @ santa pod
- 2WD COSWORTH -31 ACTUATOR
- clicking top end
- domain name selling rsturbo.net
- Hand brake light?
- Escort turbo firing order please?
- head bolts and timin belt tensioners!
- rebuilding my S2????
- STANDARD TURBO OR NOT
- s2 archs / skirts?
- dump valve (again)
- panique kit?
- trax photo's
- leaking sump gasket
- S2 Bonnet
- idle speed control valve
- Just back from powder coaters
- Rocker cover
- power steering on a mk4 rs turbo
- brake calipers,FINAL UPDATE!Hope This Helps!
- does anyone know how long discs are supposed to last .......
- Which spec S2 do you prefer?
- RS TURBO CAR COVER
- hunt for an amal valce
- engine runing poorly
- engine wont start!!
- Ignition timing
- EFI 1900CVH [BLOCK ONLY] IS IT A STRAIGHT SWAP
- what colors???
- oil cooler
- ERST T3 and Sapphire cos 2wd T3
- What turbo do i get ??
- HOW DO I TURN BOOST DOWN?
- bleeding cooling system ???
- where now
- which kind ?
- timming a kent cam
- Bailey fitting kit - Hose dimentions........
- sensor location & colours
- Sunroof wont close properly!
- How do u wash your engine bay?
- roll cage....???
- oil temp
- Rear Hub and Stub Axle
- will this fit and is it any good?
- Which oil ?
- Fitting New hand brake Cable S2 ???
- What does it mean when????
- lhd escort rs turbos
- will not start off the key !
- Dont mean to bitch but...
- What size tyres??
- thermostat housing valve???
- brands on 15th sept!
- turbos
- Fuel Tanks
- Adjusting Co Level ????
- Calling All Mechanics
- Fan override help please peeps . . . .
- yellow box
- engine stalls
- series 1 rst
- Any Advice?
- ANYBODY HAVE A HYBRID TURBO FOR SALE????
- Has anyone else had...
- Trying 2fit 2wd cossie 4 pot calipers on 2 my s1
- Actuator rod clip
- just about to buy series 2 escort
- metering head
- random....
- opinions please on wheels for my car..UPDATE PICS, WITH RIMS
- s2 cutting out !!!!
- Dimensions of the Pro-alloy IC
- all ERST boys
- GOOD MECHANIC NEEDED IN THE READING/BERKSHIRE AREA!!
- Gearbox speed transducer
- Intercoolers & Chips?
- Miss Fire On Boost
- fuel computer probs....
- Oil cooler pipes!!!!!!!!!!!!!!
- Brake disks - advice needed
- New engine pics!
- Anyone up for reshelling an ERST?
- is my car chipped ?
- Blue smoke
- chips
- what oil for service?
- re-shell
- Pic request (pleaseeee)
- cracked cyl heads
- upgrading cooler
- pics of usc and ff, now rsoc day pics
- Advice.
- AE PISTONS PART NUMBERS
- no spark (cry) now sorted
- Sunroof Question
- Urgent help,
- info needed on zetec turbo!
- chip help
- TURBO SYSTEMS MOTORSPORT
- 13cm front speakers
- Engine Smoke's
- car losing revs when accelerating ?? (what could it be?)
- Charge carriers
- Bad starting when cold
- Oil psi
- Bonnet Release Cable
- series 1 for some one here
- your own dyno
- settle an argument??
- S2 Brakes
- Horn push on three spoke RS wheel?
- bigger turbo fitted - running problems
- turbo
- Bit of a rattling on startup!
- my situation... what should i do?
- group A coils
- Just a quicky...
- meatering head chattering ??
- Going efi...HELP!
- My ERST will not tick over. Any Ideas????
- FAO T28 RST
- s1 alloys
- Reconditioned CVH block
- Engine stalls
- Bleed valve good or bad??
- Painting
- S1 & S2 Airbox Question
- best intercooler for S2?
- front bumper extension?
- Series 1 drums
- MK3 PICKUP???????
- cossie management
- help please loom?
- where can i get......
- boost prob???????
- tempreture
- pics of cobra daytonas fitted??
- escort recaros
- servo help needed!
- c41 ppc
- SERIES II GEAR BOX
- What to expect.....
- charge carrier and rocker cover help
- Ford Racing Gauges Help
- S1 running probs
- Rear Wiper not working?
- Air intake/headlight replacement.
- Whats Realistic From A Tuned S1 Engine
- cvh bottom end problem
- Tuning my S! turbo in scotland
- head trouble
- 2.1zvh,s
- SERIES 1 DRIVING LAMPS
- Best plugs & oil
- is this cheap or what ??.............
- front speaker size
