Another boost problem
Old Sep 15, 2005 | 11:36 AM
Robin's Avatar
Robin
Default Another boost problem
why is every 1 having problems with boost at the moment?
Any way i've got a problem with mine, car is standord and the boost keeps going crazey. one min it wont boost anything and the next min it will boost all the way up 2 15psi sometimes more which can't be good. i know my acuator is really soft but didn't think it could be wound out that much. any other ideas??
Old Sep 15, 2005 | 11:57 AM
Jay R's Avatar
Jay R
Dodgy amal valve
Old Sep 16, 2005 | 10:25 AM
Robin's Avatar
Robin
could be will cheak it out, how much would a new one set me back??
Old Sep 16, 2005 | 03:38 PM
zippyobrien's Avatar
zippyobrien
by a two port bleed vavle and replace the amal valve with that. you connect the hose cummin from the turbo compresor housing to one end of the bleed vavle then connect the pipe cummin from the actuator to the other end. you then blank the third pipe of (it goes to the metering head, lots of people think the car drives better with the metering head hose blocked.) amal valves are well dodgy and are the cause of most bost probs. hope this helps mate
Old Sep 17, 2005 | 08:28 AM
Rick's Avatar
Rick
3 port
Old Sep 17, 2005 | 03:25 PM
adamS2RST's Avatar
adamS2RST
Na, it wont boost to 15+ psi if its standard...it'll shut you down before then
Old Sep 17, 2005 | 03:32 PM
Robin's Avatar
Robin
thats what it says on the boost gauge
Old Sep 18, 2005 | 03:03 PM
adamS2RST's Avatar
adamS2RST
thats what it says on the boost gauge[/quote]
Then either the guage is faulty and way off, or it is chipped
Old Sep 18, 2005 | 05:32 PM
Robin's Avatar
Robin
well on the bright side it does chatter really nicely
Old Sep 22, 2005 | 11:26 AM
db's Avatar
db
I think your actuator has to be replaced. Boost peaks are typical to a worn actuator.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
