rs turbo over heating problem
she starts fine and runs fine
but the temp gauge only comes up just into white
when i remove water filler cap water over flows
could this be a faulty thermostat sender or is it the head gasket
Don't remove the filler cap, the system are under pressure. The boiling point of the water will be higher if the system is under pressure. When you remove it, the pressure will drop and the water will instantly boil.
sounds to me like the fan switch is not functioning! get a hair clip or somthing like it and pull off the plug that goes to switch stick the hair clip in the two terminals so that you are by passing the switch to run parallell! if the motor kicks in then the fans ok and you ,just need a new switch!
If however nothing happens then there could be a fault with the fan
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
track.focus'd
12-08-2015 05:53 PM
