PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. brake compensators
  2. help please
  3. Millers 10w-60 oil
  4. VI Performance OBD Monitor & Fault Code Reader
  5. Injectors for 2.0 zvh turbo?
  6. dash2 or stack ST700
  7. sad times
  8. Collins/Pectal/Powerchips monitor. Where have you mounted yours?
  9. Servicing Electrics...
  10. Which oil for Rs turbo?
  11. Quaife gearbox kit
  12. Not boosting properly
  13. what do i have to change to fit a cossie t3 to my s2?
  14. Chargecooler Resevoir Cap Is Seized On
  15. the wheels on my s1
  16. Standard recaros with harness
  17. S1 intercooler?
  18. series 1 and series 2 inlet manifold, the same?
  19. Adjusting clutch arm
  20. got a resto thread in the resto room
  21. It actually runs :d
  22. diffrent options for clocks in a series 2 dash ???
  23. speedo problem
  24. Name that wire ???
  25. head bolt washers
  26. Uprated BC box mounts
  27. steel rods an forged pistons
  28. Crank Position Sensor Bracket Pics
  29. conversion MFI to EFI (MS2-Extra) problem run engine :((
  30. Oil Return Leaking
  31. new to the scene.....
  32. we need a good mod for this room
  33. ET20 wheels?
  34. my old car b88 eeg
  35. been asked many times, ABS removal slight issue
  36. stuff it time to break it up but im keeping the shell
  37. Xr3i 1.6 Mfi to RS TURBO Mfi
  38. Changing gear - HELP!
  39. Mk5 servo and master cylinder conversion pics and question inside
  40. S2 wheel bolt torque?
  41. is there a water way that needs blocked on a zetec block to make a zvh
  42. radiator fixing problem
  43. mahle pistons
  44. Rod bolts
  45. Anybody have spare Recaro runners?
  46. who wants st170 discs spacer kits...
  47. Are the following worth buying??? re: insulation
  48. Dump valve chucking out oil????
  49. Few problems with my RST - only owned it for 2 days
  50. what should i do with theese pistons
  51. yet more problems, need some help please
  52. piper cam
  53. Interior seats
  54. Cam belt and tensioner..
  55. Cutting out MFI engine loom?
  56. spax vsx kit for fiesta
  57. Fuel tank or cell
  58. fao crazycage or rick
  59. pic request
  60. can anyone id these cams??
  61. engine mount
  62. Sunroof Seal
  63. Changing steering colunm?
  64. Turbo refurb?
  65. best gearbox upgrade for 2.0 zvh
  66. dipped and main beam headlamps, indicators not working. HELP.
  67. dipped and main beam headlamps, indicators not working. HELP.
  68. Bucket seat
  69. Converting zvh back to zetec?
  70. Newman or Kent Mecanical followers? :-)
  71. changing ecu
  72. 20,000 threads in here
  73. EFI Help needed
  74. new favourite pics
  75. Anyone know if this is standard??
  76. Pics of MTX boxes in ERST's
  77. Big brakes to fit under standard wheels
  78. grs intercooler
  79. Little & large jack
  80. Thermo Time Switch
  81. advice
  82. fuckinh hell panels have gone up in price
  83. Snapped my T3 water pipe.
  84. just got the car home
  85. escort rs turbo f reg no starting help
  86. fitting pop outs
  87. 8j x 17 rear alloys with 215 tyres, will they fit?
  88. morette head lights
  89. Removing front hub/wheel bearing?
  90. Is it a tall block?
  91. best place for panels
  92. learning to mapp
  93. New to the Ford world!
  94. driveshaft removal
  95. starting my car
  96. Pulling to the right when breaking hard
  97. tracking ?!?
  98. is my alternator on its way out ????
  99. what clutch 240-260@flywheel
  100. Kent Cams!
  101. non abs brake reservoir where from?
  102. flywheel bolts ARP or STANDARD?
  103. aeroquip
  104. genuine and non genuine pannels
  105. Whats happened here then?! lol
  106. few pics of the s1 its nearly there...
  107. Desperate 'cheeky' request
  108. Alternative starter motor for S2 RS Turbo
  109. st 170/ mondeo brake up grade brackets
  110. temp and fuel gauge
  111. For anyone who's run in a Newman cam
  112. Bailey oil breather wrecking my metering unit?
  113. starting problem help lads
  114. Main bearing caps
  115. pace double pics ??
  116. Wheel stud conversion lengths?
  117. Stay 17s or go back to 15s ?????
  118. Striped out caged
  119. cossie brakes,few questions.and picture
  120. s2 lsd??
  121. escort rs turbo s2?
  122. slight problem?
  123. Roof repairs
  124. Leaking oil feed.
  125. how much difference between .48/.55.63
  126. Hydralic Lifters / Cam Followers
  127. Another whats it worth?
  128. Another whats it worth?
  129. Clutch/gearbox issues...
  130. S2 Upgrades, whats the best beginner mods?
  131. 2.5 or 3inch exhaust system
  132. No fuel pump kicking in on my rs turbo ??
  133. best place to get a turbo?
  134. Sodium filled exhuast valves?
  135. Stage 2 T3 .36 to small for 2.0ZVH
  136. 17" diamond cuts
  137. co pot and sensors
  138. Question about ERST fuel computer.
  139. Starter motor wiring! S2
  140. Zetec Turbo lads! Dry Sump?
  141. S2 not running right
  142. absolutely gutted
  143. want to sell the gotech mfi and fit ms.....
  144. over heating problem help
  145. avoid ebay seller called rsturboparts.
  146. wot size wheels do i need to fit over cossy disks and callipers on s2
  147. went out to the garage today :)
  148. Valves anyone help
  149. Anyone used Rose Joints instead of Tie/track Rod Ends?
  150. Central locking?
  151. MTX75 shift towers
  152. RS-owner from sweden
  153. Safety devices cage.
  154. hi all
  155. t34 limits
  156. How do i remove my brake servo?
  157. please help repiping brakes.
  158. head trouble on my rs
  159. spot weld size
  160. Engine out shots of bulk head fuel lines and what top mounts?
  161. Series 2 rs turbo, abs
  162. rear chassis legs
  163. gearbox question
  164. Went to janos today!!!
  165. Looking at buying an RS Turbo
  166. HELP, Needed ASAP! Inlet sensors
  167. anyone going to middlesex rsoc tomorrow
  168. which fuel tank for my 1989 s2 mfi
  169. st200 ID
  170. gotech mfi
  171. EFI inlet
  172. Front strut bump stops/dust covers
  173. How Lucky is this
  174. Compomotive wheels
  175. how much power can an ap 4 paddle handle?
  176. escort rs turbo f reg clifford alarm problem
  177. no fans
  178. how to get more chatter
  179. quick rack (steering rack)
  180. Cobra seat runners.
  181. Can you still get Steering Rack plastic cover thingys new??
  182. 1.8 zvh rs turbo 90 spec
  183. Who is running braided fuel lines????
  184. Engine spec
  185. Dry sump
  186. escort rs turbo f reg
  187. rs 2000
  188. cylinder head question
  189. 4x4 conversion??
  190. fuel pump bushes
  191. suspension witch one
  192. conrods? pistons? efi.....
  193. Speedo question
  194. farndon rods
  195. Vin Plates
  196. electrical or alternator
  197. fuel system for modified rs turbo
  198. which head stage 3 head or zetec?
  199. Megasquirt upgrade to MS-II and 3-bar Map HELP
  200. new rs owner sayin hi
  201. How mental is this! Twincharged cvh fiesta
  202. mk 4 passenger rear quarter panel ???????
  203. Starter problem.
  204. anyone got a finis code for cv gaitors
  205. underbody resto advice???
  206. Shaky ebay ad - 2.1ZVH RS ??????????
  207. Thinking f buying a S2
  208. Clock bulbs
  209. mondeo/st170 brake upgrade help
  210. alternator bracket help
  211. trying to choose a turbo for my 1.6 cvh ......
  212. standard or abit of a modded look?
  213. my new s1 project
  214. Nasty!
  215. ERST panels
  216. S2 88spec clocks
  217. My restoration questions. brakes and lines
  218. s2 wiring problem, any ideas??
  219. S2 Indicators
  220. Head Thickness?
  221. piper T2 or newman stage 3?
  222. mk4 escort rs turbo head cloth wanted
  223. whats your best mod on your car
  224. s1 panels ,whats available from ford ?
  225. erst timing
  226. steering wheel mk3 helpppp
  227. battery
  228. big bore
  229. Magnetic sump plug
  230. So who's coming to the Pod on the 24th?
  231. on the dyno at Dastek today
  232. Carbon bonnet
  233. baileys breather pipes
  234. Distributor cap
  235. Blanking plug that fits behind coilpack,where can I find one?
  236. boost controller
  237. wanted big brakes for escort rs turbo mk4
  238. Flexi exhaust section..
  239. rear trailing arm bush??????????????????
  240. 6 1/2 inch speakers in the foowell
  241. cvh gearbox question
  242. blonde question
  243. ace cafe london old skool ford tonight
  244. Anti rollbar options with link bars
  245. S2 Gearbox
  246. FRST Fuel Pressure Regulator
  247. Misfireing???
  248. S1 steering wheel
  249. poly bushes
  250. converting a base model to cvht mfi?
