Converting zvh back to zetec?
if the holes have gone into the water way which mine never then chemical metal them
im not sure mate never used t2 i know peoplehave used t on zt before tho im preatty sure u can use the standard zetec cam sensor but dont quote me on that i know that you can with omex
Wye Valley Hardcore
You'll have to check the compression ratio as well as the combustion chambers on a CVH head are bigger than a Zetec so if the compression ratio is already highish for a ZVH set up, it will be too high for a zetec turbo. Alot of people had this problem when they started using Acrilite pistons for ZT use as they were origonally designed for ZVH use.
Wye Valley Hardcore
For ZVH you should really use the early C20XE pistons which are N/A pistons, but high quality pressure cast Mahles. Can take 5-600 BHP. The serial number on the bottoms starts 86P
C20LET turbo pistons (also pressure cast Mahles) are better for Zetec Turbo as the compression ratio is better. LET pistons in a ZVH usually gives too low compression which makes it laggy.
Rather than starting a new thread, I thought i'd continue this one.
Currently I have a zvh and going zetec,
I have the adapter plates for the exhaust/inlet.
have a fiesta inlet
pectal management.
What other bits are required?
*what water pump/from which model (2.0 zt)
*what oil pump?
* Pectal has a coil pack, can i bolt this straight onto the zetec head?
* any issues with water pipes and re routing them?
* am I right in thinking the st170 headgasket is fine?
* Will any oil pipes require changing?
Cheers guys
have a fiesta inlet
pectal management.
*what oil pump?
Cheers guys
just a quick, have a chat with crazycage off here, was a customer of ours but now is a good frind and helps out with a lot of work, he can fab the inlet and exhaust, check out my build thread in the resto section, even though its a zvh build he makes the zetec ones as he has made the ones on his car and on ricks of here, both well in the 300's
just food for thought mate. Keep us posted on your progress and if you need any help just holla
cheers raj, looks good on your motor! i think for the moment I'm going to be running the fiesta inlet and current exhaust. however saying that I most probably change my mind! lol
cheers
cheers
09-10-2015 07:38 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
