mondeo/st170 brake upgrade help
10-10-2010, 07:36 PM
Fleet Manager
mk3 mondeo/st170 calipers is std the servo man enough?
what brake lines do i need?
tech drawings for spacer and what bolts do i buy?
10-10-2010, 08:08 PM
Fresh onion..
I have had st170 on mine for a few years, standard servo is fine and standard brake pipes with braided hoses works perfect
10-10-2010, 08:31 PM
Fleet Manager
sweet guess i'll fit that up tomorrow
11-10-2010, 09:21 PM
Fleet Manager
got my calipers now just gotta get disc and fitting kit any info is much appriciated
12-10-2010, 02:59 PM
rs turbo from Greece...
Just use your std servo. Try to find the fitting kit from ebay. I bought mine for 13-14q and there are the spacers and the new bolts. You don't need to change your brake lines if they are in good working order. The only think you have to do is to drill the hub because the new bolts are M12 and the std M10... Is very very easy mod, don't worry!
12-10-2010, 03:02 PM
12-10-2010, 08:04 PM
Fleet Manager
good stuff dont seem to be any on there at the moment tho
su just drill and tap to m12?
12-10-2010, 09:33 PM
Balls Deep!
No tap, just drill, the threads are in the calipers not the hub
12-10-2010, 09:34 PM
Fleet Manager
13-10-2010, 06:02 AM
are you using mk3 mondeo callipers and discs? looking to do this as an alternative to cossie as there is many mondeos in scrappys. cheers
13-10-2010, 06:07 AM
Balls Deep!
No, Mondy calipers and pads, Focus ST 300mm discs,
13-10-2010, 07:58 AM
thinks its time for 1 of karlos's "for anybody intereted in......................."" guides
13-10-2010, 03:13 PM
Balls Deep!
Quote:
Originally Posted by
studabear
Do I do that many?!
lol
13-10-2010, 06:30 PM
There always a good read though
13-10-2010, 06:34 PM
Balls Deep!
Well if they help a few people out thats the main thing!
13-10-2010, 07:50 PM
Fleet Manager
if i get all the bits i'll take all the pics and right the guide out could be a sticky like cossie brake one
13-10-2010, 08:02 PM
13-10-2010, 08:06 PM
Fleet Manager
14-10-2010, 06:28 PM
wat size spacers do you need or is it just a simple bolt up job?
14-10-2010, 07:20 PM
Fleet Manager
u need 12mm spacers and longer bolts, then drill the hub carrier holes to m12 then bolt on
15-10-2010, 12:48 PM
glad to hear original servo is up to job but i've read the upgrade to a mk2 mondeo servo is very worthwhile, anyone tried it?
15-10-2010, 07:54 PM
Fleet Manager
ive seen it done on mk2 fiestas but not escorts
17-10-2010, 11:17 AM
12 spacers. Don't fancy that much tbh. No better ofset discs ?
17-10-2010, 10:56 PM
Fleet Manager
dont think so off the shelf can have bells and rotas made
lots of people do it you ever seen how things like aps/wilwoods mount lol
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
braided ,
brake ,
brakes ,
escort ,
lines ,
mk3 ,
mondeo ,
rs ,
spacers ,
st170 ,
turbo ,
upgrade
