S2 88spec clocks
S2 88spec clocks
Am i right in thinking that you can remove the clocks with out taking the whole of the dash out only the front panel. Also any easy trick to get the plugs dissconnected also how many plugs are there in the back
cheers
cheers
Escort Cabriolet Owner
ok there is two plugs at the back plus speedo
easiest way is to put hand through where the fuel comp would be
un plug first connector
lift forward putting the left side of clocks back in (so they slot behind dash)
giving more room to un plug speedo and second connector
hope this helps
hope this helps
07-10-2015 12:56 PM
Mr S1
20
27-09-2015 04:06 PM
