Pulling to the right when breaking hard
Old 23-10-2010 | 07:26 PM
kermitt's Avatar
kermitt
Default Pulling to the right when breaking hard
Looking for some advice here. Was out for a run and was testing my brakes (cossie discs front, std drums rear) and noticed it was pulling badly to the right when braking hard. ABS has been removed.
I know my tyre pressures were fine cos I just done them before I went out so just wondering what do I need to check.
The car has hardly been used for a nearly a year due to a long engine rebuild but the brakes were overhauled this time last year and were fine on the track.
Also I have since stripped the rear trim out so just wondering if I need to adjust anything to compensate for the lower weight?
Any help would be much appreciated?
Old 23-10-2010 | 07:33 PM
Karl 3dr's Avatar
Karl 3dr
I think the first thing i would check is wether the passenger front caliper is working, if only the drivers front brakes are working on the front it will pull to the right.
Old 24-10-2010 | 12:24 PM
jonny s2's Avatar
jonny s2
as above mate caliper could be shot
Old 24-10-2010 | 01:00 PM
**caz**'s Avatar
**caz**
I had the same with mine last year, the garage tried to tell me that it was the caliper, i told him before he charges me for that i want him to check the brake hose...low and behold its the brake hose that had collapsed and not the caliper, so check that before ya fork out on the caliper
Old 24-10-2010 | 01:07 PM
RichieST's Avatar
RichieST
How would a brake hose collapse under pressure?
Easiest way would be to take it to an MOT station with a couple of packs of biscuits and get them to check it for a brake imbalance. Will only take a couple of minutes.
Old 24-10-2010 | 01:44 PM
phil_focus's Avatar
phil_focus
i'd take the callipers off, clean them up, clean and grease the sliders and then fit back together with a smear of copper grease on the important bits. also check the hoses are ok while your down there.
if callipers are all ok and the discs and pads are in good condition and its still doing it its time to check tracking and suspension components.
Old 24-10-2010 | 01:46 PM
**caz**'s Avatar
**caz**
It was on the MOT that it was picked up on, it had been only slightly noticeable when driven, but it was on the MOT rollers that it was obvious! The Break hose was the problem, and was replaced and re tested and now problem since!
Old 24-10-2010 | 10:15 PM
kermitt's Avatar
kermitt
Gonna run it for a bit during the week and see if it frees off as its maybe just stuck from lack of use. Failing that will strip the brakes at the weekend and investigate.
Think I have cossie discs and std RS calipers but not sure as were already fitted when I bought the car. If the calipers are shot I would prefer toreplace with something new and better.
Would mondeo calipers fit straight on with new pads?
Old 25-10-2010 | 07:35 AM
Karl 3dr's Avatar
Karl 3dr
I had an escort a few years back with a siezed on nsf brake which turned out to be the flexi hose so it is possible.
Old 25-10-2010 | 07:43 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As above, most likely the passenger side caliper is seized.
Old 25-10-2010 | 07:54 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Or you've overfilled the gearbox with oil and it's pissed out the overflow onto your brake disc and pads..... lol
Old 25-10-2010 | 10:06 AM
Rob_DOHC's Avatar
Rob_DOHC
Your not talking from experience are you mate lol?
As above really, check the callipers, otherwise it could well be a knackered bush some where.
Rob,
Old 25-10-2010 | 08:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
er...... yes lol
Old 25-10-2010 | 09:05 PM
kermitt's Avatar
kermitt
Booked in tomorrow morning fingers crossed its a simple fix.
Old 25-10-2010 | 09:14 PM
Rob_DOHC's Avatar
Rob_DOHC
Originally Posted by Karlos G
er...... yes lol
very funny, i would be murdered if i dumped box oil on the drive!
Rob,
Old 25-10-2010 | 09:16 PM
kermitt's Avatar
kermitt
Think most of us would be too lol.
Old 25-10-2010 | 10:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's my drive!
chowfornow
14
05-01-2019 09:01 PM
timsrs
13-11-2018 11:48 AM
tankybaby66
06-02-2016 02:24 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Pulling to the right when breaking hard
