PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Arp head studs for zvh
  2. Series 1 rs turbo B399 NMX I'm thinking of buying it
  3. S2 engine bay switched live
  4. Trying to find RS Turbo - Reg C615 HCA
  5. fuel pipe help...
  6. Rev counter
  7. Rs2 sunroof question that nobody seems to know , mk5/6 escort knowledge required
  8. Stock ecu boost??
  9. S2 rs turbo with no boost?????
  10. Megasquirt help
  11. S2 d633 osd
  12. Help Please - Fuel Metering Unit
  13. 1600i and S1 tension arm thread info needed
  14. Inner CV joints
  15. Daily Duties
  16. B&M Quickshift price?
  17. Alternator fault.
  18. cosworth management help please
  19. Need some advice on rs turbo s2
  20. rs turbo series 2 sunroof
  21. Escort rs turbo overheating
  22. Getting some koni
  23. Identify my Escort RS Turbo chip.
  24. Getting hold of a Bayjoo chip for my Escort RST
  25. Fitting Focus RS box to a silvertop
  26. Slam panel/ Bonnet cable heat shield
  27. how rare is this
  28. Payen Head Gasket Quality
  29. Roof clock wires
  30. s2 still rattle from rome
  31. Gauge pod that replaces the heater vents on an RS turbo
  32. Wideband - Lean off throttle
  33. Headlamp Relay Location?
  34. Clicky pedals
  35. Escort Rs S2 engine Swap from Italy! Help
  36. Cam identification
  37. Firewall flex around steering rack
  38. Towing / moving series one to body shop
  39. s2 Fuel ECU
  40. Escort S2 height problem
  41. EFI Inlet Manifold
  42. g980luj
  43. Help help help!!!
  44. 5th injector complete set up.
  45. advice on frst
  46. upgrading a standard 89 s2 rst fmic ?
  47. Series 1 rs turbo body kit
  48. Poor brakes - Escort RS Turbo
  49. Series 1 rs turbo body kit?
  50. Mahle OE RST pistons - where from?
  51. RS Stub Axle Mounting Point Length
  52. RS turbo convertible
  53. can cvh big end bolts still be bought?
  54. Rs turbo cam kit
  55. 2wd Cossie Brakes on S2 ERST
  56. escort rst s2 high BHP running lean HELP
  57. S2 Rs Turbo Megasquirt
  58. Sunroof Blind
  59. G53VPG Merc Grey S2 - any info?
  60. Braided brake hoses
  61. Brakes locking tight!!? Help please!!
  62. rs turbo intercooler
  63. EFI TPS wiring help
  64. Inner Door Setup !!
  65. Wannabe RS Turbo owner
  66. Clutch slip/smell.
  67. Looking for build thread
  68. PTS chips
  69. Fuel ECU
  70. early s2 factory standard
  71. Thanks every one for info and help
  72. T3 turbo build.
  73. 1986 s2 rs turbo d701 pgc...any info/ old owners etc???
  74. Spot Lamp mounting question!
  75. Help with Clutch Pedal!
  76. MotorSport Developments
  77. 1.8 Zetec turbo using 1.8t VAG pistons, anyone done it?
  78. Lumpy tickover
  79. Sunroof Blind/Sunroof removal
  80. Series 2 - Coolant Expansion / Header Tanks....where from?
  81. Cutting off donor front wings - good idea?
  82. help setting up the throttle body
  83. Rs turbo mfi conversion
  84. Grey S2 E716 DTW
  85. Rs turbo brake set up :)
  86. Amal Valve
  87. Ford Escort to 1.8 zetec...can someone check my parts list
  88. Series 2 rear chassis legs
  89. IB5 gearbox issues.
  90. 7J Wheels and Arch Fouling
  91. which spotlights on 1990 RST?
  92. Inline brake compensator/reducing valves
  93. 5th gear not working
  94. Wheel bolts to studs and nuts
  95. Zvh valve clearance
  96. CVH head stud torque
  97. 1991 S2 Rs Turbo. Factory build log?
  98. Black series 2 rs turbo where abouts
  99. series 2 rs turbo/edited
  100. E
  101. S1 standard ride height
  102. S2 RS Turbo.. Non Sunroof... Did they?
  103. For the experts: fueling issue S2.
  104. Injector pipe slack !!!!
  105. Series 2 Slightly misfiring **FIXED**
  106. Forged Pistons Recommendations
  107. Aftermarket pedal boxes, master cylinder bore sizes?
  108. What alternator?
  109. usual rs turbo overheating help
  110. Which brake pads?
  111. Series 2 rev counter
  112. won't idle when cold???
  113. S2 RS Turbo feature - 30 years!
  114. RS Turbo Tuners in Norfolk
  115. Engine rebuild
  116. Should I remove the paint inside a new sump
  117. Steering wheel hub boss
  118. Boost problems. Help please. Possible turbo needed
  119. Recommend me some tyres!
  120. Advice on lowering my rst
  121. Inner Tie Rods
  122. Zetec turbo temperature oddity...
  123. which wideband afr set up??
  124. escort rs turbo s2 piston rings
  125. Rs turbo mk3 clocks help please
  126. EFI Breather Circuit
  127. Door loom rubber sleeves
  128. Airtec Intercooler fitment
  129. Choosing correct injectors
  130. Need new headlining
  131. Where from......RS Turbo front splitter?
  132. Looking for my dads old car!!!!!
  133. Coin tray boost mount
  134. Carbon fibre scuttle panel
  135. Uneven lowering
  136. Ford Escort Mk4 Rs Turbo CARELLO H4 headlights
  137. Looking for parts
  138. ZVH Cambelt Lift?
  139. WANTED for s2
  140. Genuine 1.4 camshaft
  141. MFI CVH top power figures.
  142. Twin fans
  143. Is this normal ?
  144. brodie britain racing
  145. new to the rs forum
  146. RST S2 holding back @ 3000rpm.....starting on 2/3 cylinders
  147. Inlet manifold what's best?
  148. turbo time boooost - time to upgrade
  149. Floor pans
  150. Lowering springs??
  151. Boost question
  152. What clutch for setup??
  153. anti lag question
  154. Quick question- fitting edis module
  155. Rear Wiper Bung
  156. Rst s2 cold starting problem
  157. Rev counter
  158. Which ECU is this? And is it Healthy? :O
  159. Help!!!! Can I use a mk3 oil pump on a mk4 escort turbo
  160. Which clutch and intercooler?
  161. PACE INTERCOOLER fitting kit/diy info?
  162. Full geometry settings needed.
  163. IB5 Gearbox with puma linkage...
  164. Does anyone know where these go?
  165. Where can I find one of these?
  166. Standard Engine bay Pictures?
  167. EXPLODED View of ERST Parts Website?
  168. 87TT-7F096-AB lll/3, rst or td gearbox?
  169. Escort Turbo Cooling lines (where do they go?)
  170. ECU Database
  171. Amal valve wiring
  172. Compression struts fitting
  173. Keys and Locks?
  174. rs turbo camshaft
  175. Electric door mirror connectors
  176. Who does Escort RS Doorcards?
  177. Cvh valve springs
  178. Best Actuator on standars S2 engine.
  179. early mk3 struts change to later type
  180. Brake travel
  181. camshaft
  182. New comer zvh nightmare
  183. MEF coilover fitting
  184. Lost indicators but work when hazard switch is pressed
  185. 80/90 spec question?
  186. Looking for S1 C897 YYG - Help!
  187. Front bumper mods/opinions.
  188. 2.1 zvh
  189. Sandblast
  190. Pressure fuel KE Jetronic
  191. 2wd cozzy rear parts
  192. Drive Flange
  193. Reverse switch.
  194. Genuine ford oil pump cvh ( anyone got one?)
  195. Fast indicators
  196. S1 popping and spluttering
  197. Help fitting gotech
  198. RS turbo S2 coolant temp sensor, 3rd one
  199. Mfi to efi
  200. Rs turbo sandwich plate
  201. stg3 t3, gt28, t34 etc. turbo spec help
  202. Speedo cable
  203. 1.8 zvh cosworth management
  204. s1 rs turbo fuel pump
  205. crank sensor/mounting bush
  206. back box issues
  207. Engine is easily started only cold!!!
  208. Efi turbo problems
  209. stage 2 turbo specs please
  210. Cvh Oil cooler seals
  211. Newbie introducing myself
  212. Best MEF setup and does the RS500 cooler fit ?
  213. Whats needed for a coil pack conversion
  214. 2.1 Zvh Rs turbo GARAGES
  215. newbie post ....over heating
  216. Escort rs turbo turbocharger help
  217. Odd kid creations
  218. Battery clamps for battery
  219. Suspension kits what's best alrounder
  220. Rs turbo speedo not working
  221. Slipping clutch after brand new clutch fitted
  222. Bearing clearances?
  223. Series 2 1990 speedo facia
  224. S2 80spec header tank?!
  225. Rear lights stuck on?!
  226. MFI 'Regulated' pressure reading
  227. S2 mfi won't idle?!
  228. What management ?
  229. Lsd help..
  230. Refitting efi flywheel after skim
  231. ABS relay
  232. Rear brake compensator help
  233. Softlines
  234. S2 Brake master cylinder rebuild kit
  235. Removing cvh oil return
  236. s1 efi over fueling
  237. MK3 wings
  238. Zvh engine help please
  239. Standard or smoked, yay or nay
  240. Fuel Trip Computer ERST s2
  241. Clutch pedal hunt
  242. Zetec Turbo Air filters
  243. Rs turbo heater packed in
  244. Escort turbo wiring mfi
  245. WANTED Rs turbo mark 4 series 2 Non runner or Rolling Shell
  246. What ECU choices are out there?
  247. Bore wash
  248. Escort rs turbo bumper moulding
  249. Erst clank
  250. which injectors after beiges on ofab
