Rear lights stuck on?!
Since I have had new management wired in and the original management loom removed my rear lights switch on with the ignition?!
Do the rear lights share something on the original engine loom or do you think it's something has been broken/disturbed removing/re fitting the dashboard?
Thanks.
Thanks.
Found the fault. It wasn't the tail lights, it was the brake lights (thought they were a bit bright when the old man said the tail lights are stuck on)
I faffed around fitting a new throttle pedal and brake MC/Servo and now the brake pedal has moved a touch and doesnt press the brake switch far enough.
morg65
Escort Range
04-01-2016 07:42 PM
