Lsd help..
Old Jan 12, 2016 | 07:05 PM
Cameron's Avatar
Cameron
Default Lsd help..
Need a bit of help..
Fitting a ka endura gearbox into My series 2 to go down the hydraulic route..
Stripped the gearbox to fit a series 2 lsd.. Ground the crown wheel from the ka box to fit the rs turbo lsd.. New bearings fitted.. But now when building the gearbox up and tightening the casing down the diff locks up due to being too big.. Anyone had any issues like this? I've checked for a shim behind the diff hoping to put a smaller shim in but there isn't one fitted..
Help!!
Old Jan 13, 2016 | 05:58 PM
mentalasanything's Avatar
mentalasanything
I wouldn't mind knowing the answer to this, I'll be building one myself in the not too distant future.
I had presumed the Escort crown wheel was used?
Lee
Old Jan 13, 2016 | 06:15 PM
xrmalin's Avatar
xrmalin
I've done three of these conversions now & never had any problems.
Do you have the preload washers the right way round ?
No lee you need to use the crown wheel from the ka box as the gears wear in together so if you used the escort crown wheel it'll whine like mad.
Kevin'
Mar 22, 2016 10:07 PM
Gary @ RS CLASSICS
Jan 5, 2016 05:27 PM
Escortdriver1
Ford Focus RS
Jan 1, 2016 04:22 PM
Ian e34 m5
Dec 26, 2015 09:24 AM
Tim Wharton
Music & Car Audio Chat
Dec 20, 2015 02:40 PM
