I have a f reg rs turbo s2 and have a problem with it. It starts but don't go over 3 thousand revs and runs lumpy please can some one help , compression is ok , changed leads , changed dizzy , thank you.
Checked for air leaks,metering heads are notorious for faults,air flap inside metering head,cam timing,I'd check those things first.
Unsure about metering head though and how you check it.
