Series 2 rev counter
Old 08-05-2016, 09:31 AM
Andyrangy
Andyrangy's Avatar
Default Series 2 rev counter
I have recently fitted a new loom into my series 2 and now have no Rev counter there is no power at the plug
Where does the Rev counter get a signal from? it was working before I fitted new loom
Old 08-05-2016, 10:23 AM
studabear
studabear's Avatar
Green wire at the coil if I remember correctly.
Old 08-05-2016, 02:38 PM
boeb
boeb's Avatar
Is it still an mfi loom you refitted or u upgraded to efi
Old 08-05-2016, 06:01 PM
Andyrangy
Andyrangy's Avatar
No still on MFI loom what is the little box for that the green wire runs into just after the coil ?
Old 08-05-2016, 06:44 PM
studabear
studabear's Avatar
2 wires? Suppressor?
Old 08-05-2016, 10:37 PM
Andyrangy
Andyrangy's Avatar
still no joy tested for broken wire all seems fine removed dials and tried 12 v direct onto Rev counter pins and it never moved any help or suggestions
Old 09-05-2016, 05:47 AM
Andyrangy
Andyrangy's Avatar
The car isn't running properly it's as tho there is a slight misfire could this be related to the Rev counter not working
Old 13-05-2016, 10:06 PM
Andyrangy
Andyrangy's Avatar
Found the cause of the Rev counter not working a broken wire between the coil and where it goes into the fuse box traced fixed got the Rev counter working 👌
Mattcortina
14-05-2016 07:59 PM
Tabbi
11-05-2016 06:23 AM
timsrs
Ford Escort RS Cosworth
07-05-2016 04:09 PM
Paulallan
26-04-2016 05:58 PM
M K
19-04-2016 08:38 AM
Quick Reply: Series 2 rev counter
