View Full Version : Ford Escort RS Turbo
- S1 accident. Anyone see it ?
- Dizzy o'ring seal
- EFI and CPS options ?
- Steel Con Rods
- Sunroof problems!
- Just posted pictures of my S1 in the gallery!!!
- Fitting a roll cage to ERST
- caliper bracket
- newbie saying hi
- Seen a mint black s2 today
- what have u beat (love this topic)
- popin in and out of gear change ???
- My standard S2!
- RIMS
- hunting on idle ??
- S1 spots. Yes or No ?
- engine colours ?
- splitter choices for 90 spec bumper?
- Swirl Pots and Oil Separators
- head gasket best one ?
- -31 Actuator????
- battery light
- roller rockers
- Holding Back, Sounding like a Scooby & Backfire like ALS
- S1 engine bay pic request
- Sounds
- intercooler???
- -31 actuator???
- Rear quarter panel
- NORMAL OR IS IT???
- bad boy bonnet
- boost guage
- not looking good
- 7 spoke rs alloys
- series 2 abs removal
- Does a cam knock?
- BRAKES NOISY!
- early and late
- where can i get series 1 weather strips ford no longer do
- my boost gauge reads -20 on idle my mates reads -8?
- Front mounted intercoolers
- seans idea of good condition ,RS turbo
- My S2
- RS Bumper Extension
- Help needed
- starting problem
- £900 Not bad?
- REAr WinDows
- HELP HELP
- AHH BOOLOCKS, just broke somethin!
- What Power is a Hybrid Stage 1 turbo good 2?
- forge twin core IC
- PRO ALLOY
- Recaro passenger seat reclining by itself...
- how to remove steering wheel
- rs turbo water and oil mixing
- SERIES 1 UNDER BONNET DECALS
- metering unit mods, any down south that can do it?
- Parts
- Boost
- Escort cozy rims on series 2
- What valance?
- VIDS
- escoz rims on an s1
- side skirts
- Fuel filler
- Feeling bad
- Swapping Turbo and Exhaust
- do you know this car??
- calipers
- Buying a Chipped Ecu HELP HELP
- S1 sunroof leaks
- Car wont start
- cants see dials?
- What Power? Any 1 wanna guess?
- Escort Rs turbo S2 Vs Renault 5 Gt Turbo
- OIL PRESSURE GAUGE
- S2 HUBS.?
- Removing Turbo L Bend.........
- Belive EFI is the way4ward?
- RS Focus box into an RST?
- s2 box into a s1
- hi been joined a while
- throttle cable help pls
- Ideal f/wheel camber setting for rst...
- cossie ECU ?
- Help needed on oil pipes
- Ecu????
- 8x17 wheels
- 94(m) transit front calipers on a rs?
- squares????
- ZVH fueling
- Ford Motorsport Bodykit, anyone know what i mean?
- help !!!!
- My Presious RST ( 2 )
- My presious RST
- 180 BHP HELP!!!!
- IS IT OK
- thermostat ?? jammed shut
- Sump Valve that chatters
- cossie wheels on escort pics?
- pic of my camz
- whats the cost of building a ZVH bottom end??
- Traction
- what is piston slap
- S1 help please . . .
- Slight play in turbo
- Did a 1.52 round Donington
- what headgasket you recommend?
- what colour would u have ?
- S2 DOORS ON AN S1
- New turbo and cam....need help
- rebuilding top end
- Boosting
- refitting gearchange linkage
- Petrol???
- Rear Disk Conversion using Mondeo Brakes
- Stage 1
- Wet Floor
- Im going to see a RS S2 today
- help on bottom end re-build
- defo headgasket ?? not sure
- zvh how and why ?
- Hot start problem
- North east rolling road
- Re-spray
- well it finally went !!
- Final drive ratio's
- 90 Spec
- zvh
- RS Turbo engine rebuild
- ECU Chipped or NOT????
- cvh oil pumps
- zvh conversion????
- suspect head gasket has gone
- S1 Graphics
- PICS
- Bleed valves
- Turbo
- Cold start
- Stage 2 Turbo
- short throw shifters?
- Power Engineering Booked
- Whats it worth
- How do i put pics on here!!
- Standard T3 turbo
- Differences between ERST Engine and the FRST Engine
- Considerations for high powered S2's
- S2 turbo wont idle at all ?????? What could it be ?
- Suspension....again
- Clutchs
- anyone know this series one for sale?
- escort glass
- EFI and Cossie Management
- mk4 dash for mk3
- gearbox help please
- Coilovers
- Help,im a beginner!
- pinking in every gear
- S1 skirt on S2
- Standard Gearbox...?
- std blue graphics or black wot do u reckon
- saph 4x4 intercooler
- big brakes?
- ERST
- BEST BACKBOX?magnex,scorpion,mongoose
- Flamer Kits
- ALTERNATOR TROUBLE
- Part number required?
- no heat at all
- boost hoses???
- Tinted glass YES or NO?
- will this fit??
- RUNNING IN OIL
- info needed
- Has anyone ever...?
- info wanted s1 / s2
- Strange Ignition Timing
- rs turbo workshop manuals on Ebay?
- serious problems
- Fuel tank for S1
- Can you fit??
- S1 Fuel Hose, can someone do me a favour plz ?
- opening rears
- Rear Discs?
- fuel pump gone???
- S2 ECU's
- Pic request
- Off to JAMSPORT
- buying an s2
- ZVH RUNNING VERY HOT!!!
- springs
- rocker arm
- Temp Guage
- pic request please.
- UH OH! Low compression :o(
- De-locked
- Abs
- IS THIS NORMAL
- I need to upgrade my brakes, suggestions/advise please!
- esc running bad any ideas
- s1/mk3 replacement panels
- S2 toe settings
- Samco hoses
- Please let me know.
- Thermostat
- Bonnet Raisers
- gearbox help
- bonnet problems
- Where is the cold starter valve
- best pistons and rods for s2 16valve turbo conversion
- Heat shield
- Intercooler
- push button starter wiring? help!!!!!!!
- management cossie or other ?
- Light switch
- hot air
- WHAT THERMOSTATE AND FAN SWITCH??DO U USE PLEASE HELP??
- Picture request...
- kent cvh 35 camshaft kit where from?
- Intercooler
- Couple of pics of my 2 latest babies 80's old-school
- Please prove my 106 rallye driving mate wrong...
- hybrid dizzy
- engine missfire
- Screamer
- My gearbox has just blown into pieces :(
- WHATS THE BEST CHIP? any recomendations?
- Bhp
- Head gasket just gone
- silly questions
- stiillllllllllll fuel filling probz !!
- All those after a D plate S1:
- Repainted blue S1
- can someone tell me the size of the speakers in the footwell
- What power do you think???
- popping flames
- whats best way of fitting laguna splitter to 90spec front
- Yum Yum ;-)
- Rs Insurance Cheap or Not
- help my rear suspension is driving me mad
- rst engine... will it fit?
- Rolling Road Setup
- leather interiors
- Newman cam
- Which Possition on the Metering Head to which Cylinder?
- Long distance drivin in an rst
- Gauge Still Reading Hot!!!
- whats needed to hit the 200bhp mark on a s2 turbo?
- Are they easy to fit
