s2 box into a s1
the casing on the S2 box doesnt have the bolt holes to fit the S1 mounts. You either need to change the suspension setup on a S1 to S2. Or changing the casing on the gearbox for a S1 casing (I think MK5 escort also has same casing as S1)
the only difference is the FRONT mount as a s2 doesnt have the holes in the front of the box for the front gearbox mount, weather u can drill and tap your own im not sure. found this out when i had to exchange a gear box the other day
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
