EFI and Cossie Management
Re: EFI and Cossie Management
Originally Posted by diamonds
or am i just talking shit
2 different types of system. Fit one OR the other. Pointless going to one type to then remove it to fit another.
cheeRS
so what do i need to fit cossie management. could i do it myself?
Loom Cosworth 2wd
ECU Cosworth 2wd
Throttle Body Cosworth 2wd / 4x4
Idle Valve Cosworth 2wd / 4x4
Ignition Amplifier + Heat Soak 2wd / 4x4
Crank Sensor Cos (Now Phase Sensor) 2wd / 4x4
Throttle Position Switch Cosworth 2wd / 4x4
Fuel Regulator Cosworth 4x4
Water Temperature Sensor Cosworth 2wd / 4x4
Charge Air Temp Sensor Cosworth 2wd / 4x4
Injectors STD Cosworth 2wd / 4x4
Map Sensor 3Bar
mk3ste
17-10-2021 10:09 AM
deathrider666
28-09-2015 06:12 PM
