View Full Version : Ford Escort RS Turbo
- bonnet lift
- turbos
- rear roll cage dimensions???????
- insurance
- Time / Clock
- NEW T3/T4 FITTED (PICS)
- not good news!!!!!!!!!
- My RS
- water seals on a pillars
- rebuild or find cheap motor ???
- What wheels for S1
- series1 leak?
- s1 turbo on s2
- Tuners ,Rolling road in Kent?
- bad news!!!!!
- 17" BK 166 Alloy wheels on a s2??
- tonight i mapped my own car
- s2 door/boot seals
- spec r header tank
- Anyone know of my old s2
- Adjusting the metering unit
- Where can i get my turbo reconditioned???
- What size silicon hose
- Identifying -31 and Chipped ECU.
- the s1 might have to go
- Measuring ACTs
- 17x8 on series 2??
- running lean???
- Gotech Management...
- power
- does this look like a Piper camshaft??
- Cossie management
- help esrt s2 not starting????
- S2 90 spec brakes
- NEWBIE
- gearbox or clutch?
- black rs on white compomotives
- Series1 wot mod next
- cam kits
- FINIS coce required please, any one know?
- ABS REMOVAL
- boost probs
- right...
- chips
- Hi my RS S2
- Whats it worth ?
- Mk3 Cab to Turbo Conversion
- Oil pressure ? Question
- car pulls all over road when on boost
- 2.1 questions
- Help.....Needed asap!
- Just won this.............
- Brake master cylinder and t-connection thread size
- Places for a new/re-conditioned standard t3 for an S1?
- parts wanted
- Rocker Arms
- 1800 pulley and CPS
- Newman Adjustable Tappet Settings
- quaife A.T.B
- my new rst
- Help with alloys header tanks
- Opinions......if you please
- What's the best direct fit intercooler for my s1?
- Cosworth brakes on a S2
- knock sensor
- ROT
- Best place to get arch repair panels???
- Fitted boost guage, now dump valve is delayed?
- parcel shelf
- Fitting a Pro Alloy Intercooler
- ZVH Engine management
- 2.1 ZVH Build.....parts required....
- Some Pics of my new S2
- correct offset for erst??
- FAO Mr Series1AJC!!!!
- 1.9CVH, Where do I go now!!......Managment?
- Porsche Injectors
- 2 litre zetec turbo
- heater matrix
- how easy to change g box mounts?
- Problem bleeding brakes
- maram sharft
- turning up boost on rst
- rs turbo mfi xr3i mfi do they have the same fuel pump
- pics of new large radtec cooler anyone?
- Brembo vs anyother?
- chipped ecu
- l.s.d
- Pics of my S2 getting some resto work for this years shows
- Piston rod gone
- Deflex Poly Gearbox Mounts... Any Good???
- MOT advisory
- help , measurements needed
- ZVH head bolts, what do you use?
- S2 running probs
- What power will this engine make ?
- steering wheel in rst
- Master Cylinder
- tuning standard erst engine
- Looking for S1 Braided Oil separator Hose's.
- hoyray another rst to the fleet
- fan not cutting in need help
- Newman cam......
- dash conversion pics wanted
- Cam Removal
- Safety Devices roll cage
- Boost pipes n dump valve
- what does an s2 break for??
- cold start valve
- steering wheel retrim
- Fave RS videos?
- efi swap?
- S1 dash
- What the biggest
- bottomin out
- numberPlates
- S1 fuel hose
- How do you value an s1
- series 1 or 2
- Mapping
- S1 gauges
- oil filter
- wax and wash for White S1??
- S2 popping & cutting out
- Full steel bottom end, when do i need it? and what to get?
- Megasquirt on my rst?
- Traction
- series 2 loom - sensor plug colours
- S2 Boost
- spark prob
- Series1 cuttin out
- Sloppy change
- S1 & S2 Gear Ratios?
- B + M Quick shift II
- got this back from being shot blasted today....
- Cossie management
- wont start, pls help
- 16v turbo base engine help
- What alarm???
- ne1 got a spare coil!
- s2 rs turbo
- Series 1 miss firing at low revs
- OIL PIPES
- Petrol guage
- Spare Wheel Well
- compression ratios
- lifting/jacking up an Escort
- Another wierd boost problem?????
- So Happy
- MANAGEMENT OPTIONS ON A S2
- Uprated Alternator?
- Speed output - Chrisitan
- rev counter probs on 88 spec EFi conversion...
- retrim
- s1 clean up
- piper 285t2
- throttle housing
- rollar bearing turbo
- S2 boosting funny
- Std cam timing figures
- what engine for zvh
- water feed to/from turbo
- S2 box onto S1
- best build for 200bhp??
- throttle positioning sensor
- wiring diarams
- mongoose zorst
- zvh questions
- Idle speed on S1
- RS turbo - Lost V5
- CAM BELT COVER
- xr3i inlet on series 1
- help, m.o.t for s2
- 1.9 tall block build - it runs!
- Bumper Inserts
- Big Thanks to Twins!
- S2---S1 parts
- fitted new head started fine now wont fire
- S1 parcel shelf and dash
- please advise me
- oil pressure
- Information Needed - RST Conversion mk5b escort
- Pic of S2 pistons from above
- 205/65 rubber on a RST rim?
- mfi to efi
- checking vehicle
- OIL IN CHARGE PIPE, INTERCOOLER & THROTTLE BODY
- CAM BELT
- where do u mount ur 3 bar map sens on cossie managment S2
- sunroof
- What are your views?
- Willwood or Hi Spec?
- Help with S1 radio wiring!
- Roll cages
- need ya help S1
- Help!!!! Please
- does r&d quickshift replace the linkage?
- Wheel Off set
- what colour plugs go were help under throttle body
- 16 valve turbo on Manual Fuel Injection
- Fitting ST170 Brakes
- My S1
- Powder Coating Alloys
- S1 Ancillary hoses
- HAVING A VERY BAD DAY
- actuator
- rs mudflaps
- Difference in cam
- s2breaks
- Bouncing Rev counter
- Piper 285 cam probs
- speakers
- No boost, help!
- Harnesses?
- good tuuner nr midlands
- s1 heaters wont work now?!
- RST Spoiler
- s1
- Where and what do u think?????
- Best induction kit?
- powerchips
- escort rst with focus rs engine
- what parts ???
- using amal valve as a switch for a dump valve, how?
- can anyone help with rs turbo clocks ?
- BEST FOR TUNING RST OR FRST
- bought myself a donor but
- arp stud and nut kit escort rs turbo
- Presure
- What Engine?
- RST wonky seats.....
- fuel pipes
- Piston rings
- standard set up rst - 12psi???
- Sunroofs and rust
- top end richness
- part numbers for clips underneath
- autostyle oil breather problem!!
- ZVH help ref oil cooler
- Boost help
- what bhp ?
- S1 RST rough running?
- ford bush kits
- how much more money for 300 bhp
- swirll pots
- piper cam
- ERST probs
- 88 spec interior
- Quick rack for an s2
- series one fan not kicking in? and heaters arnt very hot
