Sloppy change
Just a bit of info. If you are buying a quickshift to sort out ur crappy gear change, be aware that it isn't always going to be the cure. There are linkages that wear at the gearbox end, and u only get replacement bits for the acutal gear lever in the kit
Originally Posted by Jano_OddKidd
STD linkage bars are naff.
I use a steering colum knuckle, cut off and welded in place of the STD factory knuckle.
Also if you use Puma internals it will be the same as a Quickshift.
Money spent = £15
Money spent = £15
Originally Posted by Christian and Beccy
I have seen another piece of info in the last few days about how to improve the S2 linkage and might try that out soon.
Also, B&M is the ONLY way to go IMO for shifters. I have used the Rally Design type set-up and it isn't even close to the feel of the B&M.
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
