what colour plugs go were help under throttle body
cant work out what plug goes where under throttle body inlet manifold
there are four plugs black blue yellow and brown
can some one please put me right
thanks
thanks
All the plugs and sockets are colour coded with the exception of the cold start (blue plug) which socket is as stated above below the plenum with the banjo connector/follow the fuel line from the metering unit. The yellow plug connects to the yellow socket , black to black + brown to brown. Vary hard to get it wrong. Good luck.
Originally Posted by Stu @ M Developments
Originally Posted by HORNETS7
blue cold start
black auxillary air device
yellow thermo time swithc
beige temp sensor
beige temp sensor
