Idle speed on S1
Idle speed on S1
Tried to adjust this as car was ticking over at 2000 rpm, car was fully warmed up but nothing happened then about 2 hours later the car wont idle any ideas?
You can adjust the Idle base speed by using the sprung loaded screw under the throttle body, should only do it when the car is fully up to temp on an S1.
