rs turbo mfi xr3i mfi do they have the same fuel pump
nearly got car ready for mot
been a long haul can see the finnish line ahead
and fuel pump starts to wine
is it me or are these rs turbos jinksed
been one thing after another
any way i have a fuel pump for a mk4 xr3i mfi
are they the same as the mk4 rs turbo
thanks
thanks
It depends, some of the XR's/injected Orions had a different sized fitting
with a smaller banjo on the end of the fuel pipe. You can still connect the larger RS banjo to the pump but almost invariably there will be a small air
leak, which will mean it's a bitch to start and even when you do get it going
the ingress of air into the system means that 30 mins after you turn it off
re starting is VERY difficult. With any luck you'll be OK/if the outside diameter
of your pump output is 11.75 mm you're fine if it's smaller welcome to my club.........
Matt Baxter
16-09-2015 08:30 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
