16 valve turbo on Manual Fuel Injection
Does anyone know if a 16 valve turbo has been successfully run on standard RS turbo management or if at all possible?
Of course there would be problems such as attaching dzzy and suitable inlet manifold but I am sure they could be over come with some good engineering.
Would be interested in hearing others experiance or knowledge on the matter.
Cheers.
Cheers.
Cheers for the feedback lads.
I know what you meant about running it with mfi but if I get the engine built and running on mfi will just upgrade to cos or stand alone ecu etc l8.
Thanks fo that pic T28 rst, it has given inspiration, will get on with sourcing an engine to build now. Do you know any more about the car in the pic like did it run ok?
Originally Posted by LEEUK_RS
where the fooks the dizzy go ?
looks like a very well thought out conversion i bet it drives lovely
It's cheaper and easier to run a MFI. Especially if you want more power
Think what you like to.
But both must be set up properly for the 16V!
There's another possibility to attach the dizzy:
Matt Baxter
16-09-2015 08:30 PM
