PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107
  1. FAO all of you runnin mongoose on ur s2
  2. Good after market ECU
  3. oh no, Now my Turbo's gone
  4. EFI Conversion
  5. How do you fit a ERST Boost guage??
  6. Help needed please
  7. vulcanengines
  8. anyone ever snapped a driveshaft
  9. lighter
  10. pic request
  11. Series 1 rear disc conversion!!!!!
  12. Which management system is the best to use?
  13. new comer
  14. rear brake line info needed (yes something else broke lol)
  15. Pic request of S2's with front pro-alloy intercoolers fitted
  16. Found something that might be interesting for people on here
  17. relays. oh god plz help!
  18. crankcase breather
  19. Coilover's on S1/S2 Discussion!
  20. 90 spec door cards
  21. wiring looms
  22. Pumaracing double valve springs
  23. dip stick is very lose? not good?
  24. head work
  25. Pics of s2's on sixteens please
  26. Boost Controller
  27. Deflex gearbox mountings mk2
  28. Car hesitating
  29. Replacement panels S1
  30. wullie young s1 spec
  31. S2 servo and master cylinder question....
  32. microdynamics 5th injecotor computer
  33. anyone running diamond cut rs 7 spokes
  34. advanteges of going efi (s2)
  35. Series 1 gearbox re builds
  36. XE OR CALIBRA TURBO PISTONS???
  37. IS A T25 TURBO GOING TO BE ANYGOOD FOR ME???
  38. newcomer
  39. oil/crank case pressure problem (keep killing gaskets)
  40. fuel pump
  41. What cam are plp using?
  42. Washer bottle rubber
  43. Focus Rear Discs
  44. Bailey breather kit fitting
  45. wheels rubbing arches mot fail!!!
  46. Brake warning lights
  47. Not what I wanted to hear
  48. dash in dash out
  49. S2 Problems please help
  50. took my car to a sprint track
  51. can anyone help with where to get these bits for my s2?
  52. Mk3 escort clear rear lights
  53. my cars in the mag
  54. Rear Disc Conversion on S2
  55. bloody great (box probs)
  56. Brakes
  57. Looking to buy cam and kit
  58. Pace Charge Cooler Fitting
  59. Series 2 engine bay earths, advice needed....
  60. RS Turbo - Too much crankcase pressure?
  61. project E111NWD 270bhp erst begins!!! with pics!
  62. Modifying in reverse, can anyone help
  63. Clifford cox engineering based in Reading. any info?
  64. What Wheels?
  65. can u buy rear brake cylinders new
  66. Fuel Pump wiring
  67. Will these wheels fit with this suspension?
  68. I was told that.....
  69. Does any one know what a dump valve controller is
  70. Brake problems also
  71. Standard ERST fan switch, what temps should it cut in &
  72. What type is the stock ERST LSD?
  73. A new bloody problem!
  74. braking on a s2
  75. After 2 years i can't get it to start
  76. new car :) need help please!
  77. turbo water coolin
  78. my car going in Fast ford (hopefully)
  79. Why it still leaking!
  80. B856 CYA
  81. Turbo problems
  82. Anyone changed metal brake pipes for braided?
  83. Do I need a new Rad???
  84. best £-bhp mods
  85. newbie needs all the help in the world!!
  86. Series 2 not idling properly....
  87. Just Bought a knock around
  88. ST170 Brakes
  89. Yip, Ive definitly blown the head gasket!
  90. Attended my first RWYB. launch techniques?
  91. 1.8 CVH Rubber rocker cover gasket on an RS Turbo
  92. coil wireing help
  93. Has Anyone Got?
  94. Rear brake
  95. S1 advice
  96. i need a small number plate
  97. Magnex fitting question
  98. Disaster pls HELP
  99. Can someone list mods upto 200bhp?
  100. metering units
  101. escort cossie wheels on a s1?
  102. did s2 bonnets have sound proofing?
  103. Rebuild Day has arrived!
  104. Common probs with S2's?
  105. Getting the Inlet Fannymold off - any tricks?
  106. Series 1 Pace intercooler??
  107. Rev counter stopped working
  108. st 170 brake set up bleeding problems lol
  109. series 2 rad length and height ?
  110. help please major problem with brakes
  111. I hate Problems!!!
  112. [b]best TV 80/90s series[/b]
  113. rolling roads
  114. series 1 top boost hose length
  115. What Oil, Plugs and leads!!
  116. injection system?? help needed ASAP
  117. ABS prob?
  118. bleeding brakes
  119. look at my poor car
  120. Car pulls side to side over bumps!
  121. Power?
  122. 1988 F Reg ERST wont idle at all, please help me
  123. F Reg RST's n rust
  124. anyone got a spare bleed valve???
  125. engine swap
  126. What sort of boost can i look to be running?
  127. samco hose
  128. Boost?
  129. fast indicators and not blown bulb
  130. Mates turbo, weilding
  131. Not very optimistic were they
  132. co leval
  133. AP has a new organic clutch kit available !
  134. Dump valve problem
  135. what brake hoses?????
  136. Want to build a low comp bottom end!
  137. spluttering/hesitating?
  138. Fuel Pump and injectors
  139. water contamination in oil after h/gasket failure...
  140. * How many miles to £15?
  141. S1 Radiator.....
  142. the famous clutch question again..
  143. What will this lot achive ??
  144. not taking a dump?
  145. best 80s/90s tv series(poll gone)
  146. brackets for wilwood 4 pot??
  147. Whats involved in putting efi in a series 2
  148. wheels should i keep or change
  149. fuse probs
  150. MFI 2 EFI
  151. S2 wiring Diagram needed
  152. Hey everyone
  153. part number/ finis code or if anyone has one???
  154. how to get 180 hp
  155. bit help plzzz
  156. Will an S2 box fit onto an S1
  157. knocking noise turning right , help!
  158. Advise plz
  159. Reprogrammed fuel ecu: S2 MFI
  160. Quick question
  161. Over heating??
  162. 18's
  163. external wastegate!!!!!!!!!!
  164. S1 oil feed pipe
  165. charge coolers
  166. will these rs wheels fit on my series 1??
  167. help please
  168. intercooler?
  169. need a quick answer please? dash question
  170. wheres that tastey Julie bird ;)
  171. ERST couple of Q's
  172. Misfire under load - Doin my head in!!!
  173. Has anyone got any pictures of different coloured s1 wheels
  174. water injection escort rs turbo
  175. ERST MFI Help
  176. Escort S2 front mounted intercooler
  177. setup a CVH34 kent cam
  178. Is this true ?
  179. injectors
  180. Losing Coolant
  181. heater control - how do you take em out/put em in?
  182. Pic's of my new tubular manifold
  183. How do you change the....
  184. Removing Snapped Head Bolt
  185. Timeing adjusting itself....HELP
  186. fitting a cossie cooler
  187. can you get a uprated oil pump
  188. New gearbox and uprated clutch
  189. Rough mixture settings for my RS
  190. Pipes on the amal valve
  191. boring in here tonight
  192. Extra pipe coming from charge carrier
  193. Engine advise
  194. single rear door(van)
  195. Anyone know of any decent paint garages around the M25 area
  196. Anti roll bar problem.
  197. * Insurance @ 19 and general Q's about ERST's
  198. Will a MK3 suspension kit fit on a MK4?
  199. Tuners in the midlands
  200. WTF just happened ?
  201. 3 questions from a n00b
  202. need a door, where from?
  203. Gutted
  204. pics of ya cages!
  205. Gearbox Oil
  206. no fuel to the injectors :(
  207. Fitting MTX75 gearbox
  208. pinking at 125+
  209. well fcuked off now!!!!!!!!!!!!!!!!!
  210. HELP!! TOO SLOW!!!
  211. RED HOT TURBO
  212. Headgasket gone after couple of weeks!!
  213. IDLE is too low
  214. Wilwood Brakes
  215. Hot hot heat
  216. gearbox
  217. series 1 gearbox mounts
  218. cossie brakes
  219. strip or not to strip?, that is the question
  220. 250BHP?
  221. MFI 2 EFI
  222. rev counter being strange
  223. Gear Oil
  224. Quick,stupidly easy question! SORTED
  225. My New Interior
  226. major oil leak coming form under tray beneath g-box
  227. Brembo calipers?
  228. Weird sound and movement from engine bay
  229. do we need uprated ht leads????
  230. Where can i buy...
  231. pics of my escort
  232. Weird boost problem that i aint got a clue about!!
  233. braided master cyl brake lines!
  234. FUEL PRESSURE ACTUATOR THINGIE
  235. Clicking
  236. What lowering springs??
  237. Best oil viscosity for ZVH...
  238. Lack of performance....
  239. S2 Relays
  240. Is it possible................
  241. best valve springs?
  242. cosworth rear disc conversion
  243. 2.1 cosworth management questions whats pectel all about????
  244. turbo timer problems (link too)
  245. No Spark???
  246. dying between 5 and 6 thou
  247. ignition lights
  248. Fuel Metering Unit.
  249. How fooked off am I??????
  250. zetec information
