View Full Version : Ford Escort RS Turbo
- running in new cam
- need a turbo for a series 1
- standard suspension, opinions please
- mk3 dash carpet and what to treat them with
- RS Turbo Fuel Tank Help
- s1 and s2 bottom end help please!!!!
- For you S1 fans!
- Decal Question
- Std Dashboard Picture
- ABS removal
- Rear brake pipes
- WANTED
- ST170 rear discs and calipers over S1 7spokes?
- would this fit?
- Diff sun gears
- rs 2000 turbo ?
- Where have the Threads and Posts gone????!!!
- Wheel catching caliper?
- HELP, rs s2, starts like a dream when it get warm cuts out
- Cosworth inlet on CVH?
- Plz settle a bet !!
- clutch change and abs question.help please!!!
- Gearbox Question
- Breathers?
- How long will it take me to swap engines?
- Fueling prob with s1
- Just a quickie, aree head bolts re useable?
- newbie hi all
- Lambda probe help please??
- Suspension Interchangability
- how to wire, Air/fuel ratio gauge in a erst
- Help needed with engine!!! Please look
- rs doing my nut in
- Powerflow exhaust
- brake problems
- wheel offset and size
- New engine help
- rs turbo cills
- lowered pics?!?
- cts stg1 box
- Oil choice??
- How Hard Isit To....
- cooling fan idea.
- Ap Racing Clutch or Helix Clutch
- Wheels
- Carbon heater fan cover?
- laguna spliter
- cossie greens
- mfi to efi adaptor plate
- intermitant braking - any help please...
- Cheapest place for bits?
- tuner
- Rebuilding my old bottom end, how do I know what size con rod shells?
- how much brake fluid is needed?
- overheating/idle control
- oil help!
- Trim
- electrical gremlin
- Mk5 disc's on a mk4
- Can I get my engine out the top?
- drive shaft nuts
- braided brake hoses???
- temp guage help
- Gear knobs
- MFI and Boost
- running issuse
- Looking for a garage
- running problems
- Irish racing RST's
- Brake upgrades?
- do these sets fit into a fiesta
- fuel pump issue
- which handles better
- How do i fit afr gauge?
- complete sunroof removal`
- linking clifford alarm to central locking, S2 ERST
- mpg
- Leather interior
- Piper or Kent T2 or T3?.(FiestaRST)
- Megasquirt help needed on my RST
- Actuator help....
- Just slapped my splitter on!
- fueling issues
- S2 RST Rear window antenna amplifier problems..
- Heater Matrix Removal?
- is an s1 tailgate the same as an s2?
- oil probs
- rs turbo f999 jtv rs turbo b656 jrm
- I need help engine/ boost problem
- Not getting any fuel
- should i use the amal valve?
- How much is a standard head, cam and inlet worth?
- Kent CVH34 Tolerances
- Adjustable rear arms
- Need some help please on rebuild
- central locking fitment
- anyone had these problems on a rear disc conversion?
- Quickracks
- clutch cable
- high-level spoiler
- XR3i parts on an ERST?
- Will 17"x7.5" comp mos fit erst
- brakes
- cold start valve goosed?
- How much water does the rst hold?
- what would be better??
- A Dragging Clutch...
- Finis # 6810428 what is it?
- few questions?? its my first rst s2
- loose wire????
- What gives first when raising the Rev limiter?
- Back on the rd 1 day and its broke
- New wheels for my S2
- clutch quadrant black or white s2 !!!!!!!!!!!
- A few pictures and a video of my rs turbo at Milton Keynes cruise
- fuel pump?
- Central locking and electric windows upgrade
- my new s2
- "rusty" water in my engine
- pics of my S2
- ADVICE Turbo Oil feed hose with or without pre-filter
- were is the diagnostic plug to?
- Do you know where this car is
- Rev Counter Not Fully Working
- Roose hoses
- cossie management with efi inlet
- fuel pump holder??
- New article for download Bosch K and KE in depth. [3 parts]
- main end bolts
- Fixed rate shocks?
- rs overheating
- could one of those be fitted to a rst gbox?
- rs turbo parcel shelfs
- what do you reckon
- How do I upload a pic?
- Cambelt cover - safe without?
- Battery problems?
- Cossie Calipers???
- I know its been covered loads of times but...
- Questions to make a conversion of Ke to efi
- silver zetec piston or black zetec pistons
- brakes problem
- my rst s2 starting problems
- need one of these asap
- Cosworth management pics
- s2 no boost
- Getting 2psi of Boost at 5,000 RPM
- Heated Front Screen
- boost levels
- S2 rst oil
- 200bhp
- Zetec conversion
- Power Run
- rs2 overheating
- Newbie with Qs
- dash clocks
- 1
- Skimming head
- HELP with my s1 project
- Audi tt 225 v 200+bhp series 2
- efi clocks
- mk3 conversion
- samco boost hoses
- 17" softspokes
- ?? ZVH Dipstick Tube Fixing ??
- any info on this reg ?
- Skatter valve/Chatter box
- Oil in boost pipes?
- are erst and frst cailpers the same?
- RS Turbo Feels Hesitant :(
- Thermostat fan switch..
- abs fluid
- Any 1 have a solid shell for sale (escort rs turbo, xr3i)
- Finis codes for inlet & exhaust stud&nuts for rst
- heat wrapping charge carrier
- No Boost
- Adjustable rear suspension offer?
- Lightweight flywheel
- flywheel
- Arp big end bolts
- Lightweight panels
- front mounted intercoooler
- CTS Gearbox arrived today!
- torque settings please
- efi conversion problem
- jano oddkidd
- Heat problems after fitting airtec intercooler on rst
- am i missing something?
- dump valve
- ZVH Pulley Spacer Query
- Mk 3 escort on ebay...
- s1 engine mount
- did ne body see 5th gear rs turbo
- It hurt alot. my first ERST that hit a lamp post .
- bonnet spacers
- oil cooler fans
- rs2000 rear disc brake set up
- rs turbo H191 GVS history?? did you
- Sr2 escort rs turbo gearbox problems
- s2 gearbox rebuild kit question
- Thermostat switch???
- anyone heard of carrera custom design house
- head gasket
- AirTec Rad/Intercooler
- who has the escort zetec with the RS2000 manifold on?
- ERST 60mm Drop
- cossie management question
- oil for my rs turbo??
- Wanted S2 wheels
- inlet hell
- HELP!
- torque setting's
- Urgent! Where to get 1.8zvh Dipstick from??
- 1900 cvh piston help and com pression
- ZVH Dipstick
- What sort of power needed?
- Fia headgasket
- no spark on my escort rs turbo on cossie managment ???
- My series 2 with pics
- I have the worst luck!
- big problems with my rs engine
- s1 and s2 dipsticks the same ?
- fiesta breather on escort
- Lack of feel in steering.
- louder exhaust
- Anti roll bar
- Where can i get some of these fast?
- new wheels
- meets in lancs
- top end rattle
- anyone know any history on H711WCP
- what wheel bolts when running mondeo 16"s
- Rs Turbo Decal
- no fuel or spark on my cossie mangement rs turbo
- Braided brake lines - discuss
- Where cheapest for MAHLE RS pistons???
- Stage 1 cylinder head prices
- mot faliure
- knocking
- Wheel bearings!?!?!
- big valve head
- FRST/ EFI Stage 2/3 Head Wanted
- MG ZF AP Racing calipers
- Fiesta opening rear 1/4 windows
- Offset for mk3 escort
- 1.8 blacktop into mk4 escort
- which intercooler???????
- genuine tca'a needed
- series 1 with series 2 trim
