No Boost
Just had turbo and clutch fitted on my ERST.
Was like 12:30 last night and was too tired to start mucking around again after getting the car back together and started it (drives fine- XR3i style lol) but i have no boost.
Could it be the amal valves pipes are disconnected/connected wrongly or something to do with the actuator itself?
Obviously i will look tonight after work and give it a good check over but any advice would be appreciated, thanks
Balls Deep!
Amal valve pipes go:
C=Compressor Housing
W=Wastegate Actuator
R=Return to metering Unit
These letters are marked on the Amal itself but you might need to take it off to see them.
Try winding actuator rod out 2 turns at at time until boost increases.
If you are using the same actuator as before and have not altered the rod length then leave it alone, it's probably something else!!
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
