i know im gonna get shot and called gay here
i have a dump valve and was going for the pace double capacity intercooler.my question is does adding the larger intercooler make the dumpvalve quieter?its fairly loud at the moment however adding a larger intercooler should release less pressure as the turbo wont be so restricted?
As we all know carl and have argued before depends what boost he is running, i would say if you are running under 12/13 psi they are fine anything more and you are looking at a front mount imo, and best to go for a grs or pro-alloy imo.
ive had 6 rs turbos and few of them had double capacity pace intercoolers.all cars set up at jamsport running 15 psi.never had a problem with any temperatures.people just really seem to hate the intercoolers on here lol.
IMO anything up to about 1bar (14.7psi) is fine, as this is also ok for a standard IC (right on it's limit though) so the pace should be fine with it!
Over that and you want a good FMIC
so can anyone suggest a decent one?
im only aiming at 10psi so no need for a double front mounted one
I have a pace mate and am running 12/13 psi and its well upto the job, only when you are running over a bar imo does it affect act's, so you running 10 psi will be fine, as rick says people seem to do nothing but slag them off on here, but i to have never had a problem with them.
