Oil in boost pipes?
"Ill check the stock"
Oil in boost pipes?
Stripped the gearbox out of my s1 today to find oil in my bottom boost hoses the engine is a freshly built zvh with a stage 3 technics turbo the lot has only done 1600 miles and hasnt been on the road since last november? I know it sounds like the turbo but its only done 1600 steady miles.
Any ideas?
Any ideas?
Balls Deep!
Yeah defo not HG!
If your still on MFI did you clean out the metering head,all breather pipes, and breather filter? There is generally plenty of oil floating around in them after 20 years of driving
Also if your IC is not new that will have oil in it from the previous engine.
when i had a fire in my engine bay i used my washing up bowl to put it out....after i replace all my fuel lines and what not i tryed to fire it up ..it did after a while but really lumpy and i couldnt work out why intill i took my bottom boost gauge off and found half a spagbol in there ..pasta and all sorts..lol had to replace everything lol
When i built it everything was spotless and new breather system and pipes etc.
And yes i think iv been over filling it with oil ill clean eveything immensly and see what happens!!
good stuff, may have you a little job mate..... brookes needs new battery tray annd some bulkhead welding in the XR if your interested.... told him about the welding your doing on the s2 and think he would like you to do it
