PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Timing belt
  2. just found my old cab on ebay... gutted..
  3. Clutch upgrade price.
  4. Replacing a sill in Essex
  5. 90 spec spolier
  6. Rs for sale Guy off here..........
  7. This is off a rst i know that now
  8. FORGE ADJUSTABLE ACTUATOR Any good and will it fit ??
  9. Stupid question has my alternator gone?
  10. Anyone in essex breaking a rs turbo please??
  11. alot of smoke coming out exhaust
  12. rs turbo over fueling?
  13. just a lil one on my rst
  14. best efi cvh inlet
  15. front seat winders
  16. zvh turbo.....
  17. S2 calipers and disks
  18. Smoke, and plenty of it!
  19. fuel pressure regulator
  20. 2.1 ZVH How is it done.........
  21. boot pop
  22. Rocker cover does S2 fit S1 ?
  23. Best place for........S2
  24. Draining my battery on start.
  25. Heated washer jets!
  26. s2 rst still wont start HELP!!!!!!!
  27. fiesta rs turbo HELPPPPP LOL
  28. needed studs to fit gti wheels
  29. altenator wiring
  30. Fastest car for the money?
  31. mud flaps
  32. rear brake conversion
  33. xr/rs metering units..
  34. idle issue with fans on
  35. Cheapest place for...
  36. Black smoke and weird boost.
  37. S2 Just wont run!!!
  38. Whats the perfect reciepe for the top speed record?
  39. is there ment to be a starter heat shield? Hot start problem!
  40. Few questions...
  41. Whats the biggest amp battery for rs turbo you can fit?
  42. Pads
  43. heater matrix
  44. what clutch for big bhp
  45. help fitting powersteering to a RST
  46. equal length driveshafts
  47. best non-standard mirrors for S2
  48. s2 or s1 rst wanted???
  49. bigger/beter injectors?!?!
  50. new crank/shells (do i run in?)
  51. core plug sized
  52. swirl pot/breather
  53. std turbo
  54. Fusebox on a s2
  55. Anyone fitted Xenon HID kit on their rs turbo?
  56. Model Cars
  57. turbo
  58. Good ebay buy!
  59. tall block cvh
  60. Running an engine in
  61. s2 rst... Anyone got it?
  62. rear chassis rails need welding
  63. fueling problem
  64. Gaz normal coilovers or Gaz Golds?
  65. do i need a efi adapter plate?
  66. do i need a efi adapter plate?
  67. Bigger brakes on S2
  68. standard t3 turbo pic wanted
  69. Is there a difference between 88spec and 90spec clocks
  70. strut top poly bushes
  71. problems with exaust amnifold gasket
  72. diff bearings?
  73. oil breather
  74. Speedo cable
  75. my new s2
  76. inner cv joint
  77. GRP A coil fitting
  78. T 34 how good on power
  79. Roof Lineing
  80. Engine keeps cutting out when cold
  81. What Exhaust
  82. newman cam????
  83. quicky about plugs and group a coil
  84. what power through EFI rst inlet
  85. what clutch?
  86. Electrics just gets worse
  87. oops done the headgasket
  88. boost issue
  89. What would you do ??
  90. new dump valve, wont tickover...
  91. 2.0 zvh conversion
  92. Auto electrician in essex ???
  93. Stange discovery today
  94. idle screw feel out
  95. anyone gt a drivers door seal for an S2 Rs turbo
  96. gearbox
  97. What kind of power ??
  98. prices of Series 1 rst
  99. Where is the ariel on rs
  100. Front wheel bearing
  101. compbrake RST pedal box/UNIVERSAL FLOOR MOUNTED
  102. brake lines
  103. my escort rs turbo s2 has stopped boosting?!?!
  104. ignition keeps cutting out
  105. arp bolts, inlet and manifoild?
  106. Boot lid for Mk4 Escort Series 2 rs turbo.
  107. oil cooler
  108. 1.8 zetec head onto 2.0
  109. Bailey breather
  110. Why is 1 big end shell shrunk ?? Pic inside
  111. front shocks descovered lol
  112. hi im new here
  113. what is the largest turbo for a zetec?
  114. Any reason why I can't/shouldnt fit a cage to mk4 cabby?
  115. smashed s2
  116. headlight issue
  117. Help
  118. t3 turbo rebuild
  119. Fuel Computer Gauge
  120. Hw much power should a 1900 rs turbo roughly produce
  121. tyres for rst
  122. Engine Oil
  123. no electric. please help
  124. jamsport big bearing box
  125. XR3i EFi Engine Management Light
  126. Rear Chassis Legs need replacing
  127. Heat wrapping manifold.
  128. rst adjustable tca
  129. ZVH Engines???
  130. rotten bulkhead help?
  131. air and fuel guage but have no lambda ?
  132. Replacing standard
  133. How often?
  134. bleed valves
  135. super chip on a erst zvh
  136. boost limits on the ecu
  137. ACT
  138. brake pedal help
  139. Thinking of fitting a Turbo Timer
  140. Waxoil
  141. heater prob
  142. Should i fix my pace intercooler or buy a replacement ?
  143. What turbo unit is this ?? Thinking t3
  144. After almost a 5 week wait my rods are finally here!!
  145. max advance to get 12 degrees
  146. Amal valve
  147. xr3i cabby - fiesta turbo!
  148. amal valve s2 rst
  149. interpro 1800 engine
  150. Is it worth heatwrapping a charge carrier?
  151. How many....
  152. After a 195 efi chipped ecu
  153. Fitting new inlet
  154. Head lights
  155. What gauges?!
  156. Cossy wheels on s1 tyre size?
  157. Rear quarter needed
  158. FRST Air Charge Temp sensor
  159. is it worth upgrading from a pro alloy intercooler to a grs intercooler?
  160. Escort Rs t34 turbo
  161. 16 inch mondeo alloys
  162. home made bonnet raisers.
  163. fuel pipes
  164. Escort mk4 smoked indicators
  165. dash swap
  166. What actuator and where to buy it ??
  167. Gearbox upgrade question
  168. Oil in my exhaust
  169. Low exhaust
  170. s2 rs not boosting properly
  171. master cylinder question...
  172. speedo bounce
  173. exhaust manifold suggestions
  174. piston slap
  175. Oil/Tappet question
  176. Efi wireing help............
  177. zetec with gt2860RS
  178. Stupid sunroof question.
  179. oil in header tank ??!!
  180. escort s2 rst
  181. Slow turning over
  182. Leccy Problems
  183. Handbrake Shoes!
  184. Heated Front Screen
  185. escort rs turbo alternator issues
  186. some bits needed
  187. Turbo choice for forged 2.1 ZVH
  188. Light and squeeking problem.
  189. cam pulley markings
  190. air filter
  191. Wiring diagram?
  192. Simple question, what top boost hose with FRST crossover pipe?
  193. Gear box mounts :)
  194. wiring help - interior light/clock & elec. mirrors
  195. How many teeth in a 112 degrees.
  196. Escort RS Turbo rebuilt but has problems??
  197. gearbox mounts
  198. Torque plate for CVH
  199. xr3i efi throttle body cable wanted!!
  200. How to tell...piper cam?
  201. boot light query
  202. interior light queries
  203. oil breather help ????
  204. Xr3i efi to RS turbo, how?
  205. Switches
  206. Identify my ECU
  207. What do i need for PAS
  208. 90 spec stereo help?
  209. Tune up & rolling road
  210. Rolling road results
  211. best suspension combo?...
  212. Escort rs running problems...help plz!
  213. Heat Shield?
  214. Hearta and Diamonds ecu
  215. Tunning and setups
  216. 200SX exhaust manifolds
  217. where to have omex 710 set up on a escort rst
  218. 2.0 Silvertop - 6 speed ST170 box
  219. how to remove inner wings
  220. Clear front indicators????
  221. Piston Help please
  222. Its alive again!!!!!!!
  223. Are erst and xr3i fuel injector pipes the same ???
  224. Rocker cover
  225. Had my S2 set up
  226. shiney stuff plans
  227. Where do people get the target figures from
  228. put your power where your mouth is,
  229. Escort rs turbo with coss wheels
  230. My First Ever Respray!!
  231. megassquirt or L6 on ZT engine?
  232. chipped ecu
  233. safety devices cage question
  234. Cosworth or ZVH Engine In Escort Rs Turbo?
  235. when was the first 90s spec rs turbo made
  236. backfire when turn engine off, but injectors are fine
  237. few more rear suspension geometry questions (with pics)
  238. mk4 lights
  239. cylinder head cast numbers
  240. Series 1 rs turbo genuine or not ????
  241. How do you value a Series 2?
  242. knocking sound...
  243. Series 2 Brakes
  244. rear strut brace affecting geometry?
  245. bonnet vents
  246. Rear arches gone
  247. Β&Μ short shifter
  248. Fitting a FMIC without a setup.
  249. RS Turbo Efi conversion
  250. Silicone hose?
