fuel pipes
does anyone know the size of the thread on the mfi injectors.
also need to know the size of the thread of banjos in the mfi meteing head
many thanks peeps
many thanks peeps
one other thing, the injectors themselfs are fixed flow right?
what i mean is, if i upgraded to -3 areoquip, as its slightly wider than pipe at the mo, they aren't suddenly be chucking in loads of fuel.
basically what i want to do, is redo the fuel lines in braided hose, in
6mm id from the bulk head, thru the accumulator to the metereing head.
from here use the dash -3, or -2 if i can get the fittings small enuff.
i've seen these kits about for about £140ish, but that seems a bit steep!
155lee
06-09-2016 11:10 AM
