GRP A coil fitting
GRP A coil fitting
I've had my coil fitted for a couple of years now however over the millions of posts with regards to this type of coil i've seen people mention different ways they've wired theres up.
I simply cut the old connectors, fitted spades and away i went.
However some people have said they relay'd theres for more power(voltage not HP) at higher rpm and others have said they re-wired it via the battery for a fresher (not 20yr old) feed.
Is there any 'real' benifit to doing either of the above or is just fitting it as i have done adequate?
PassionFords Creator
Hi,
Pop a multimeter on the coil live and earth it to chassis, extend wires into car and give to a passenger then go for a run, if you have less than around 13volts at high revs on boost then its worth rewiring it, however, if that is the case, check you have the voltage at the battery itself before presuming its old coil wiring causing your problems.
steerfromdarear
28
29-01-2016 06:14 PM
borboyous
22-08-2015 11:17 AM
marky_g
15-08-2015 10:43 AM
155lee
14-08-2015 11:21 AM
