ERL aquamist water injection fitting help
Fleet Manager
I've taken the old set up of my Mfi RS turbo and now want to fit it to my EFI xr3i turbo but the pray use to be activated my a pulse from the coil
Obviously I don't have coil now I have coilpack how would I get the same signal I have the handbook that came with it but I can't get my head around what I need to do
Anyone else got this system fitted?
Fleet Manager
According to the instructions You use the negative from the coil to pick up an RPM pluse? Any ideas what I could use instead as I don't have that it recommends CPS or Alternator
Fleet Manager
In the instructions is says CPS or alternator, yer Its wasted spark EDIS ignition apparently pin 2 will give me the rpm pluse but have no ideas how I would test for that, is it just going to be a 12v trigger that turns the relay on? Or something more complicated
I'm likely over complicating things but I don't want to assume it's working set the boost high and fuck the engine want to run 14 and 20psi switchable like I did in the RST
Always a pleasure!
Your ECU has some spare outputs that can activate water injection if needed mate, you wouldn't need the ERL controller, just pump and injectors etc.
marky_g (14-08-2015)
Fleet Manager
Oh rely! Sweet have to look into that then I'll mount the pump and injector and we can go from there then? It's all legal now just got rebuilt the rear brakes before I bring it in for a map
As above Karl will be able to sort it. The ecu can activate the water injection based on what ever inputs you can think of. RPM & Boost for example, or TPS & RPM.
I would probably do it for RPM and Air temp or boost and air temp. For example when Boost was over 12psi and manifold temp was over 40deg. etc.
Fleet Manager
Yer that's how it already works I think it has a pipe that goes to the inlet manifold so guessing that's the boost pressure, it's all mechanical so I think the pressure is set within the valve?
More jobs for Karl
More jobs for Karl
09-10-2015 07:38 PM
