How many teeth in a 112 degrees.
How many teeth are there in 112degrees roughly. and is this clockwise or anti as you look at the pully, kent pully and supersport hyd cam.
thanks in advance.
thanks in advance.
It's the crank that you rotate 112 degrees not the cam. The crank needs to be 112 degrees after TDC cyl 1, and the cam needs to be at full lift inlet valve cyl 1.
Lee
Zoggon
10-08-2015 10:39 AM
Ima-Racing500
17
23-09-2004 11:31 AM
