just a lil one on my rst
hi there my car starts fine and runs well but wen i have my lights on it seem like its using all the power and car wont idle proply it just poters out.any ideas any one plzzzzzz im thinking alternater ???
the tick over is high any way but when its idleing and u put the lights on you can hear it start to die its fine wen the lights are dipped its doin my head in
PassionFORD Member
Does it only do this when you have the lights on? What about rear screen defroster or rear fog light? If it only does this on the lights then you have a huge current draw on that circuit. If not then your battery/alternator is packing up.
i think its only wen the lights are on.it wen itss drawing power from the engine.its fine drivin it but wen u stop and and let it idle for 10 mens with the lights on it just wants to die
and out a voltmeter on the battery when its on idle with all the lights, wipers, heaters etc on then see what its charging at, should be anywhere between 13.5-14.5 volts
had this same problem with mine recently, it wouldnt charge at idle but rev it to 1200rpm and it was fine, i knew my old 55 amp alternator wasnt the best anyway so i had a new 70 amp 1 built, put it on and still had the same issue, turns out auto electrics near me who built the alternator put the wrong size pulley on, i never thought to check as i wasnt aware there were different size pulleys untill someone on here mentioned it, the 1 they fitted was too big so wasnt spinning fast enough to charge at idle, they've sorted it now, now i can have the lights, fans, heater, both heated screens, wipers etc all on and still charges at 13.8v at idle and 14v with everything off.
07-10-2015 12:56 PM
