What kind of power ??
hello all. i was just wondering what kind of power i will be expecting from my car when i have my new parts on it the spec will be.
standard rst mfi engine with:
Super chipped ecu
Baileys breather
Newman cam lifters and springs
grs inter cooler
t3 turbo
Everything els engine wise is standard. for now.
Super chipped ecu
Baileys breather
grs inter cooler
t3 turbo
![](https://passionford.com/forum/images/smilies/pascontent.gif)
I'd say Muz's 160 is a safe bet.
My spec:
-31 actuator
airtec FMIC
chipped ecu
std turbo
air filter + exhaust
Made 165bhp comfortably @15psi
However the clutch is starting to go at that power. Also, on the way to getting that power I needed to improve parts. Group A coil. magnecore leads etc.. I would advise the same as it will only cause problems further down the line.
My spec:
-31 actuator
airtec FMIC
chipped ecu
std turbo
My spec:
-31 actuator
airtec FMIC
chipped ecu
std turbo
My spec:
-31 actuator
airtec FMIC
chipped ecu
std turbo
depends entirely on wot psi your turbo will do imo.
I managed 171bhp at approx 13psi on a standard turbo,
i'd say 160-180ish
i'd say 160-180ish
Super chipped ecu
Baileys breather
grs inter cooler
t3 turbo
Everything els engine wise is standard. for now.![](https://passionford.com/forum/images/smilies/pascontent.gif)
Super chipped ecu
Baileys breather
grs inter cooler
t3 turbo
not sure about the fueling, i thought it was when you went above 20psi,
power enginering suggested a 5th injector, stage 3 t3 for 22 psi, 220bhp
nowhere on this thread did other ppl suggest metering probs:
https://passionford.com/forum/ford-e...-power-is.html
so still unsure!
fin
so still unsure!
fin
Wye Valley Hardcore
Thing is with a 5th injector is they are very crude and the fuel distribution between cylinders is uneven, so pistons 2-3 could be fine but 1 and 4 running lean.
I'm one of those people who thinks if you want 200BHP do a managment swap!
Also metering heads varey so much. Some have maxed out at 12-14PSI others will fuel 18-20 no probs.
deathrider666
28-09-2015 06:12 PM
